procedure for buying rims?
Old Apr 6, 2003
RobG2k1's Avatar
RobG2k1 is an unknown quantity at this point
hey im going to get some rims for the summer probably and was wondering what exactly do i need for em, like lug nuts are a must? can stock lugs be used? when i get tires balanced and stuff does that mean my odometer is safe? also what about centering caps? damn im a newb but cant find anything in search. what do i search for rims basics or something?
Old Apr 6, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
If you can't find anything, it means you didn't search hard enough. All of these questions have been answered many times. If you're buying rims, make sure you've got the right bolt pattern and offset (4x100 and anywhere between 37 and 45), chances are you won't be able to use the stock lugs, they're ball end lugnuts that probably aren't going to be used on aftermarket wheels. Some wheels come with lugs, some you have to buy them, but pick the wheels before the lugnuts. You need to get the right taper on the nuts to match the wheels. Use the tire calc to pick the right tire size to keep your odometer close to stock. Popular sizes are 215/45/17 and 205/45/17 most people with 18's go with 215/35/18. Centering rings are a must... talk to the place you buy the rims from, they'll get you fixed up with the right ones for the rims you buy.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
If you buy rims they usually come with the lugs and centercaps. If not, you can buy lugs at local wheel shops. I doubt you'd be able to use your stock lugs. I had to buy new lugs but they were only $30. You need to get your wheels balanced every so often to prevent uneven treadwear. It's safe. The tire size I'd go with is 215/40/17.
S1N7H3T1C
Jul 21, 2015 05:20 AM
srtlat
Jul 17, 2015 11:53 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
671civicLX
Jul 9, 2015 03:22 PM
