96 hatch. P0420 code, new cat still bad.... d16y7, PLEASE HELP!
Old May 25, 2017
Juicenstuff's Avatar
Juicenstuff is an unknown quantity at this point
Exclamation 96 hatch. P0420 code, new cat still bad.... d16y7, PLEASE HELP!
My hatch pulled the p0420 threshold code, so bad that it acted as if it was misfiring terribly and go completely dead. Guy at the shop was SURE it was the clogged cat. Purchased brand new cat ($406) same problem. The car dies, and spits when trying to crank back up.. I'm sure the car isn't misfiring because I changed plugs, dizzyCap, and cables less than a year ago. It's been in the shop for a month PLEASE HELP! Thanks for any, and all help!
Old May 25, 2017
Wankenstein's Avatar
Re: 96 hatch. P0420 code, new cat still bad.... d16y7, PLEASE HELP!
Did the mechanic reset the ECU after cat converter replacement?
Was a dry and wet (with oil) compression test ever performed?
Fuel pressure tested?
Spark tested?
To rule out a cylinder misfire do a power balance (drop test)
How many miles on the o2 sensor?
Just because you changed iginition parts:cap, rotor, plugs, wires doesn't mean it's not misfiring.
Old May 25, 2017
Mechanic is broken.....Replace mechanic?
Old May 25, 2017
What about the old cat was failed?
If it broke apart, pieces could still be lodged in the rest of the exhaust causing severe restriction.
Is that the problem? HellifIknow. I'm not the one who can see and test the car.
Anything done last year doesn't mean squat right now.
If the engine runs poorly enough, even a brand new cat can be ruined in less than a minute.
Why? WHO is dragging their feet?
PLEASE HELP!
Tow it to someone who can fix cars on purpose? (Replace mechanic)
Old May 25, 2017
With all the seemingly half-assed mechanics out there I might as well buy a jumper suit and name tag and start wrenching too..
Old May 25, 2017
mac25's Avatar
Dr Krieger of Modification
Lawl!
OP, a catalytic converter is a piece of pipe that has a metal waffle/screen in it that converts deadly emissions such as CO to less harm full emissions CO2 (plus other gasses).
They generally do not fail on there own from chemical saturation for years, even a decade, depending on driving habits "... given an "average" life of about 100,000 miles...." http://auto.howstuffworks.com/under-...erter-last.htm
However, if your engine is sending far more contaminated gases than usual it can kill the cat., that's why Ezone was asking about the testing.
