PDA
View Full Version : Suspension
Pages : [1] 2
  1. Odd noise
  2. Need help identifying 2005 Civic OEM strut assembly part numbers or Manufacturer
  3. Rear strut bump stop replacement
  4. Need steering rack info
  5. Knuckle (?)
  6. Replacement of rear struts
  7. Need verification of new ball joints
  8. Steering creak mystery?
  9. Change bushings or parts
  10. Inner tie rods banging and thumping [solved]
  11. Lower ball joints without alignment [solved]
  12. Could a dirty bead be causing slow leaks
  13. Steering rack discontinued - where to find?
  14. 2002 Civic SI - Ball Joint Separator, Ball Joint Press Tool
  15. 2004 civic help to identify the part
  16. Vibrations over 55 mph, seemingly unfixable
  17. lower control arms for my 03 Civic EX Coupe
  18. Ever replace a steering rack?
  19. Need average cost to replace one wheel bearing
  20. What make of ball joints and ties rods
  21. Replacing rear suspension [solved]
  22. Mystery front end noise, steering rack? [solved]
  23. Power steering foam [solved]
  24. Lower ball joints and outer tie rod ends replacement cost
  25. Is this safe for a power steering fluid flush and fill [solved]
  26. Rear axle bushings and brackets
  27. Excessive Turn in?
  28. Strange cyclic chirp when at speed
  29. My inner tie rod won’t come off
  30. Civic 2001 99000km power steering pump Brazil
  31. Steering rack replacement [solved]
  32. Sway bar link won't tighten
  33. Another "clunking" thread...driveshafts?
  34. What do I do
  35. Inner Tie Rod torque? 2002 LX [solved]
  36. Rough ride after suspension rebuild
  37. Strange uneven tire wear 2003 civic
  38. 2004 Civic Si - Rapid Clunk While Cornering Left [solved]
  39. Shop "Couldn't align my car"
  40. Unknown front end noises
  41. Steering movement
  42. Extremely rough on concrete Highway, smooth as glass on asphalt
  43. 2001 honda civic LX strut spring replacement using 2003 springs/strut mounts
  44. Is ep3 inner tie rod compatible with 2004 Honda civic EX [solved]
  45. Grinding/Whining noises after coilover installation
  46. Stiff steering during idle after replacing power steering pump
  47. Power steering solution needed
  48. Passenger side wheel gap widened after replacing hub assembly
  49. 2001 Civic front end clunk when accelerating from stop, heavy braking [solved - info]
  50. Electric power steering, Violent shaking
  51. '05 Civic Replacing Power Steering Reservoir Hose
  52. Rear Wheel Bearing and Hub Assy
  53. Metal ring to secure ball joint boot?
  54. Roaring noise between 25-40mph
  55. 2001 Civic LX replacement front struts recommendation [solved]
  56. Control arm clunk?
  57. Metal to Metal noise under front of car
  58. Front hub and bearing [solved]
  59. Greaser with joints
  60. Play in steering rack
  61. Rattling and Squeking from front passenger
  62. Wheel Alignment after strut install
  63. Is this bad?
  64. Ok to replace only one strut with aftermarket brand?
  65. Metal tapping sound after brand new front suspension.
  66. 02 Civic Ex Steering Knuckles on 02 Si - Alignment?
  67. washer in wrong spot on subframe [solved]
  68. Control Arm Bushings Urgent or Not?
  69. Stuck lower ball joints [solved]
  70. Inner Tie Rod Replacement Question
  71. broken rear control arm bolt 05 ex
  72. Tie Rod Issues and Question
  73. Front wheel
  74. Grinding Noise After Strut Assembly Install [solved]
  75. Wheel Hop at low speeds?
  76. Blown Shocks From To Much Whoopie Makin In The Backseat
  77. Replacing control arm bushings
  78. Comfortable Suspension?
  79. Ball joint replacement? Remove boot before pressing new one in?
  80. Clicking Noise and Shaking
  81. Replacing the power steering return line 2002 LX
  82. Steering knuckle 2001-2 vs 2003-5
  83. Frame Damage on car??????
  84. Slappy steering
  85. Front higher than rear
  86. Unbalancable tires ??
  87. 2004/1.6i Vtec Sport-Steering prob after knock?
  88. Grease leaking from over stuffed MOOG ball joint OK [solved]?
  89. MOOG Rsx tie rod ends
  90. Suspension question
  91. 2001 civic lx front sway bar bracket broke, needs replaceent but $$$$
  92. tracking down source of steering wheel wobble
  93. Ride Height Problem
  94. Sway bar end link
  95. Correct ball joint removal set for 2004 Civic
  96. 2002 power steering pump leakage fixable?
  97. Honda Civic EX 2003, diagnosed with suspension and drivetrain issues at 60k miles. Op
  98. Is my top-hat in the wrong position?
  99. Wheel bearing brands?
  100. Steady grinding noise front passenger side
  101. What is the part number or size
  102. Under steering wheel leak inside the cabin and outside
  103. 2004 Civic - any need for lubrication?
  104. Tie Rod ends on truhart Struts
  105. Ball joints
  106. PS pump inside repair, seal, Oring, assembly
  107. 2001 honda civic lx 2 door coupe part swap from 6th gen to 7th gen
  108. Dangerous rear suspension problem, please help
  109. Lug Nut
  110. Front end problems
  111. Knocking sound when shifting into drive or reverse
  112. Wheel Vibrations
  113. Coold bad ball joints be causing this awful sound when stopping and turning?
  114. 2004 What power steering fluid can I add to factory?
  115. Em2 civic toe problems
  116. Car shakes with load
  117. Front hub and bearing assembly, compatibility.
  118. Bearing + Caliper
  119. Should I Replace Camber Bolt?
  120. Ball joint vs. Harbor Freight Impact
  121. Wheel Vibration When Hitting Bumps or any rough in the road
  122. Gabriel Ultra front struts and sway bar link
  123. What factors go into fixing include angle/camber and castor?
  124. Just looking for right suspension for just day to day commuting?
  125. Steering wheel shake
  126. Power Steering cutting out
  127. Terrible noisy bumpy ride
  128. Rear suspension making crunching noise
  129. New 2002 EX owner here
  130. Struts difference on civic 2005 vs civic ex special edition
  131. Will a 01 civic coil spring fit on a 05 lx?
  132. Steering pump what goes bad in it?
  133. My new CV shaft isn't fitting into my knuckle
  134. 2002 coupe rear suspension HELP
  135. Got screwed, need help.
  136. New Strut assembly popping-clunking noise
  137. Rattle noise front passenger side
  138. Suyspension feels way too hard going over speed bumps
  139. Weird noise....?
  140. I have another rear suspension bushing question
  141. Does someone have a part number for the OB rear upper control arm bushing?
  142. My new spindle nuts don't align with the notch
  143. Scraping Around Turns
  144. Can you help me diagnose this wobble?
  145. Rear strut bolt failure.
  146. Outer tie rod removal issue
  147. Noises but having trouble pinpointing
  148. Slid into curb, wheel is turned inward
  149. what is a good ball joint?
  150. Coilovers on a 05 civic dx vp
  151. Power Steering Return Line
  152. 2002 LX Clunking around left turns
  153. Issues on left turns (cornering w/e) lol
  154. Power Steering Low Pressure Hose
  155. Clunking noise is driving me crazy!
  156. Tools For The Job
  157. Suspension issues
  158. Problems after installing new struts
  159. Subframe question
  160. front subframe
  161. Rear alignment for rear strut replacement?
  162. DIY EPS Conversion
  163. Steering wheel centering?
  164. Lower Control ARM Bushing
  165. Struts bearing & inner tie rods
  166. 2001 civic lx power steering stopped working once but it's working again
  167. Wheel bearings issues
  168. Horrible wheel shake
  169. Rumble Strip Sound After Turning
  170. Difficulty w/lower control arms (L & R)
  171. 2nd Opinon on $3K Quote from Pepboys to fix Lower Ball Joints, Tire Rod Ends, Etc
  172. Alignment
  173. Didn't use power steering fluid meant for Hondas. Is that bad?!
  174. Suspension component replacement question
  175. Need a little help...
  176. hub help please
  177. 2002 Civic pulls left when accelerating
  178. Noise with genuine shocks
  179. Tie rod lock nut keeps coming loose. Please help!
  180. 2002 EX Suspension Restoration
  181. Wheel shake after eBay coilover sleeve install
  182. Reliable manufacturer for replacement components?
  183. Civic 7th Gen Suspension Height Issue.
  184. Electric power steering, my Civic refuses to return to center
  185. Strut Replacement (~OE-ish Quality), Front vs. Rear
  186. Slight pulling left/right while driving
  187. Need new front strut assemblies. Brand suggestions?
  188. Noise from front end
  189. Sotck/OE Ride Quality
  190. strut noise
  191. Lower control arm and wheel cylinder (free)
  192. MIDAS quote for suspension parts and labor.
  193. My 2002 Civic EX needs struts. What's good, yet affordable?
  194. Re doing my whole suspension
  195. 02 Civic HX strut replacement
  196. Alignment suggestions or input?
  197. Struts and Shocks questions
  198. front struts
  199. Do I need an alignment after rear strut replacement?
  200. Should I replace all 4 struts?
  201. Squeaky suspension noise
  202. Suspension re-assembly question
  203. Inner tie rods
  204. Need Help Figuring out a squeak sound
  205. 04 Rear Suspension
  206. Another Lower Ball Joint Thread: Separating from LCA
  207. How I solved my dash rattling..
  208. 2002 civic inner tie rod issue
  209. lower ball joint 03 civic ex
  210. 05 honda civic dx clunking front end
  211. 2001 Civic GX Rear Knuckle Front Bushing squeak
  212. Ball joint castle nut past cotter hole
  213. Ball joint retainer clip bent
  214. 7th gen rear suspension parts list
  215. OEM part # for suspension ball joint?
  216. Compliance bushing tool kit
  217. Weird KYB piston nut - damaged?
  218. broken bolt from rear suspension
  219. Take load off during Strut replacement?
  220. Bump stop split in half
  221. Struts (or springs) for softer ride in 2003 Si?
  222. Life expectancy of aftermarket Ball-Joints
  223. Poppin/clicking noise in suspension
  224. stupid question
  225. need new suspension all 4 wheels
  226. Struts
  227. 2002 Civic LX: Power steering stiff and whining noise
  228. Upper Strut Mount
  229. 03 Civic LX suspension help
  230. Cold Weather = LOUD rear end
  231. Control Arm - Cracked
  232. Removing EPS from my EP3
  233. Replacement Bolts for LCA's
  234. Clunling in rear - 01 Civic
  235. 2004 Honda Civic DX/VP Leans Right
  236. Where to find suspension bolts?
  237. Revamping suspension on 04 EX; Need advice
  238. Squeaking From the rear tire areas
  239. Simple alignment advice
  240. 04 civic wheel bearing repair issue
  241. installing new ball joints
  242. Strange vibration at 38 mph, like washboard
  243. Steering wheel shakes when turning
  244. Struts
  245. Help with LCA removal
  246. hi guys clunking ?
  247. Knocking sound from front end over bumps.
  248. 05 Civic rumble sound starts at 20mph (or 3rd gear)
  249. Problem strut replacement - drive shaft pulled out
  250. Horrible shaking at 40 mph
