Power Steering Low Pressure Hose
Old Jun 18, 2019
Jenndenise41's Avatar
Jenndenise41 is an unknown quantity at this point
i have a small leak in my low pressure hose. What are the labor hours for this job?
Old Jun 18, 2019
Slumpertcivic's Avatar
Re: Power Steering Low Pressure Hose
If you buy the correct hoses and quart fluid from Honda and the mechanic is skilled maybe 5 minutes actual work.
Defiantly something you should consider doing yourself, Buying a spring clamp pliers tool makes it pretty easy, the cable actuated versions for $35+ seems steep at first but once you use it your hooked...
Jenndenise41
Suspension
Jul 2, 2019 09:39 AM
teezyyoxo
May 4, 2017 10:36 PM
Sailorman3
Nov 10, 2013 11:27 AM
CivicSedan1998
Oct 3, 2013 07:52 PM
booba5185
Bolt-on Engine Performance
Aug 29, 2005 05:02 PM
