Steering movement
Old Apr 23, 2023
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Steering movement
Hi everyone. Hope I can get some help regarding this ongoing issue.
I have a 2002 civic ex VTEC model, the steering seems to not feeling good when I'm driving. If I'm on an uneven road steering will move left and right, sometimes it would do the same thing if I go over a bulb as well. What seem to be the problem here?
Old Apr 23, 2023
Colin42's Avatar
Re: Steering movement
Bump steer. Check all suspension and steering related parts. But if you're lowered it's pretty unavoidable
Old Apr 23, 2023
I'm not running lowered lol. I hate lowered cars. I'm running 17x7.5 4x100 , 35-38 offset wheels wheels.
I changed two racks now. Lower from control arms are new , over a years or so ago.
Shacks,struts, tie rods, sway bar links. and ball joints are new from the local parts Store. Other parts are new from Rock Auto. The Rack and pinion is from the junkyard but it didn't shows and visuals signs of oil leaking when I bought it.
I be having this issue for some time now. Even with my first own car, 07 scion TC.
Old Apr 23, 2023
take to alignment shop and have them diagnose it
Old Apr 23, 2023
Colin42's Avatar
+1 for this
Old Apr 23, 2023
I did an alignment yesterday brother.
Old Apr 23, 2023
The guy was saying that when he was adjusting the alignment I see the middle part of the rack was moving, I said that's where tie rods connected to and it will move from there.
Old Apr 23, 2023
then tell us in the first post
Old Apr 23, 2023
get a 2nd opinion from another shop
Old Apr 23, 2023
then tell us in the first post.
wider tires also increases the "following the road camber" effect. put original wheels/tires and check if problems persists
not sure what the 07 scion matters to the civic...
qlitten
Jul 21, 2015 03:12 PM
Saucetomate
Oct 14, 2011 02:51 PM
hondaruss
Sep 10, 2008 03:29 PM
DarkFlame
Sep 9, 2008 06:56 AM
