Horrible wheel shake
Old Feb 4, 2019
Silver_slug's Avatar
Silver_slug is an unknown quantity at this point
my wheel has been starting to shake but if I let it go for a little bit it’s completely fine so I figured it was just the road but it’s not. This morning on my way to school my wheel started to shake worse than it has before. I pulled over and everything looked okay only thing is that my breaks smelled really hot and I hadn’t really used them and when I did it wasn’t hard enough to make it smell like that. I was doing mid to low 40mph btw. But on my way home it was fine like nothing had ever happened. Can someone help me find what’s wrong?!?!
Old Feb 5, 2019
Slumpertcivic's Avatar
Re: Horrible wheel shake
Sounds exactly like a sticking caliper.
perished, contaminated brake fluid, rust on internal parts, rust on external parts, bent/ worn/ rusted caliper guides, clogged ABS port/ brake line and in extreme cases very worn out wheel bearing.
heat has likely warped the rotor which causes the shaking more so than other reason is parts of the rotor are glazed over.
Old Feb 5, 2019
I’ll check that out thank you!
APSMS
Brakes
Jan 27, 2019 08:05 AM
mhammond1127
Apr 12, 2018 01:31 PM
kornsined
Nov 26, 2006 03:12 PM
invrtdsa1nt
May 24, 2006 03:08 PM
jwalker87
15
Oct 27, 2003 12:30 PM
