Brakes Post Your questions about brakes here!
Caliper Rubbing Wheel Ballast after Brake Job
Old Jan 25, 2019
APSMS's Avatar
APSMS is an unknown quantity at this point
Hey, I was changing the front brakes and rotors on my 2003 Civic (LX) and when I went to put the tire back on, I noticed that the wheel ballast (located near the outside edge) was rubbing on the caliper slide. This was clearly not the case before (the weights did not look scraped or damaged prior to this), and I'm not sure what would have caused this, as I didn't remove the slide to change out the brakes.
I took everything back apart, the caliber off the backing plate and then reseated the pads in the brake hardware/slide. I also tried tightening and rotating the slide bolts to see if that would make a difference, but it didn't. I'm a little bit at a loss as to what could have shifted to cause this change as it doesn't look like there's any adjustment possible on the assembly.
Anyone know what could be causing this, or if it's a common problem?
Old Jan 25, 2019
re: Caliper Rubbing Wheel Ballast after Brake Job
If the wheel has sticky weights that are now hitting the caliper, peel them off so wheel can be installed and the car driven, and then go to the shop to have the wheel rebalanced (and make sure the new weights don't contact the caliper)
Old Jan 26, 2019
Slumpertcivic's Avatar
New pads and rotor vs worn down parts will spread the caliper apart some. Not usually a issue with stock wheels, but if you have aftermarket, who knows.
Old Jan 26, 2019
APSMS's Avatar
Yeah, they are nonstandard wheels (alloy rims that were previously on a 95 Civic EX that we no longer own). My dad didn't remember ever encountering this problem before so it wasn't really clear why we were having it now, but I suppose this is also the first time we've changed to rotor as well as the pads.
The car can be driven with the scraping (it's just *that* much too extended) but it makes an awful noise and some very slight transfer to the steering wheel as well. I was kinda hoping the weight would scrape down quickly from the friction since it's much softer metal than the caliper.
Old Jan 27, 2019
Colin42's Avatar
What size rim?
whatsaricer
Brakes
19
Oct 4, 2011 05:17 PM
98dx
Nov 16, 2010 08:40 AM
starfox
Brakes
Sep 8, 2009 05:28 AM
stevanrk
Wheels and Tires
Jun 29, 2008 12:28 PM
xDCx
Oct 16, 2005 08:27 PM
