squeaking after replacing stripped stud on wheel
Old Oct 16, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
ever since i installed the new rotors and brake pads, theres been squeaking from my front left wheel. at the same time i also replaced the stripped stud. I've heard before that youd get squeaking from replacing the stud, is that so? how can i get rid of it?
-calvin
Old Oct 16, 2005
burke420's Avatar
The World Is Yours!
sounds like something may not be tight enough??
Old Oct 16, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
if it is constant (always during rotations...) might be brake dust liner(rotor cover) w/e its called ...the piece of metal behind the rotor that stops brake dust and particualte from getting into coming out of the rotor....might be rubbing on the rotor
EDIT: if possible didja torque to 80 ft/lbs?
Old Oct 16, 2005
streetglower's Avatar
Originally Posted by CivicRidaz1
ever since i installed the new rotors and brake pads, theres been squeaking from my front left wheel. how can i get rid of it?
-calvin
You need to remove everything and recheck everything. Thats my best advice. If it all started after you did your brakes, then it has to be something you did when you installed them or possibly something is failing or faulty.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
elitezdc5
May 26, 2015 05:46 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
