2001 civic lx power steering stopped working once but it's working again
Old Feb 21, 2019
sean_incali's Avatar
sean_incali is an unknown quantity at this point
I have a 2001 civic lx with 190K miles. I got it used and put on very little miles. no more than a few hundred miles. i'll drive it maybe 2 times a week. Last week I was driving it to run some errands and got to the store, and all of sudden, the power steering stopped working.
i was able to still steer it and parked. And after I got done with my errands, I came out worried sick, and started the car, and the power steering was working fine again.
So I got some sealer and steering fluid to put it in, but I've noticed that is was full already. (wasted 8 bucks)
Does anyone know what's going on here? Should I be worried about this? What should I do if I'm making a turn at pretty good speed and the steering goes out again?
Any help is appreciated.
Old Feb 21, 2019
Colin42's Avatar
Re: 2001 civic lx power steering stopped working once but it's working again
do not put that sealing crap in
Old Feb 21, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Get the power steering system checked: pump pressures, leaks or hose deformations, etc.
Old Feb 21, 2019
what's wrong with it? I didn't put it in, because it was already full.
Old Feb 21, 2019
even if it's fine now? i ask because i don't have much extra cash. could it be a temporary problem that resolved itself?
Old Feb 22, 2019
Colin42's Avatar
you will cause more problems because it will gum up everything
Old Feb 22, 2019
i see. ok thank you. i haven't put it in because it's already full.
Old Feb 23, 2019
Slumpertcivic's Avatar
Possible the belt was slipping due to being worn or splashed water on it.
More likely pressure relief system in the pump is failing.
I would at least dump and refill the resivior, start car turn wheel lock to lock three times then dump again and repeate until fluid starts staying clean. Usually 4-5 times.
hans.pcguy
Jul 12, 2015 12:19 PM
tonisama
Jul 3, 2009 11:54 PM
clownprince
Auto X/Road Racing
Jul 27, 2004 08:39 PM
civicstylz4u
May 14, 2004 10:48 PM
flipryde
22
Apr 26, 2003 04:07 PM
