Is this safe for a power steering fluid flush and fill [solved]
Old Feb 8, 2024
Robertlx's Avatar
Robertlx is an unknown quantity at this point
I studied a video on YouTube as to how to flush your power steering system without a machine..I guess some of you are aware of this method. It involves using a length of clear hose and a plastic hose junction or coupler. What I want to know is, is it safe to do this with the wheels on the ground.(not up on jack stands). I was thinking about putting 2 pieces of cardboard under the front wheels so they would turn freely. One video wants you to put the front wheels on jack stands when turning the steering wheel to flush out the old fluid.
Old Feb 8, 2024
Colin42's Avatar
Re: Is this safe for a power steering fluid flush and fill
Better to have the wheels off the ground. Only use honda fluid.
epa
General 8th & 9th Gen
Apr 11, 2021 06:33 PM
bachands
Suspension DIY
Jun 21, 2020 12:06 AM
austin165
22
Jul 24, 2012 09:11 PM
booboomc21
22
Nov 26, 2009 06:25 PM
jta
Nov 3, 2004 02:47 AM
