Tie Rod ends on truhart Struts
Old Dec 11, 2020
Mrmusato's Avatar
Mrmusato is an unknown quantity at this point
So i have this problem with my tie rod ends not fitting properly there truhart sruts with skunk 2 springs the stock tie rods ends are to loose is there a set of tie rod ends that would fit?
Old Dec 11, 2020
Re: Tie Rod ends on truhart Struts
what year?
Suspension differs a lot throughout the generations
Also, this section is to review parts. We will move it later to proper car generation section.
Old Dec 11, 2020
Mrmusato's Avatar
2003 honda civic si
Old Dec 11, 2020
Strange, the tie-rod ends were not different, normally, if they are not worn out, they should fit.
Are you using new parts?
the differences are that 01-02 did use smaller diameter shocks at the front and smaller crash bolts (connecting to the knuckle)
other then that they were the same.
ah, wait, Si US or Si Canada?
Old Dec 11, 2020
Mrmusato's Avatar
there new after market outer tie rod ends from advance auto parts
Old Dec 11, 2020
https://www.civicforums.com/forums/4...atibility.html
Old Dec 11, 2020
I see a potential problem.
Their website lists RSX (DC5) as compatible. If you read the link above, the DC5 uses 13mm tie rod holes, whilst the regular civic and the hatch Si uses 12mm...
You might need to go back and get tie-rod ends for RSX instead - not sure if the threads/length fits, though
https://www.truhartusa.com/product_p/th-h511.htm
Old Dec 11, 2020
but do call or email truhart first and confirm
or measure the hole size
paulymcd7
Dec 29, 2012 06:58 PM
Coloraduh_Civic
Oct 22, 2006 07:54 PM
HondaNation
Jul 16, 2005 07:49 PM
2002excpe
Jan 16, 2005 01:37 PM
VNlilMAN
15
Apr 17, 2002 05:45 PM
