Compliance bushing tool kit
Old May 9, 2016
threeoten's Avatar
threeoten is an unknown quantity at this point
I am going to try and swap my compliance bushings. Does anyone know which OEM press tool kits I will need to loan from autozone?
Old May 10, 2016
threeoten's Avatar
Re: Compliance bushing tool kit
Anyone know? Is this the one, or are there others that I would need?
http://www.autozone.com/test-scan-an...set/94806_0_0/
Old May 10, 2016
Take your new bushing in (and the control arm) and match up whatever tools fit the parts.
You'll need one cup that can push the outer ring of the bushing AND fit through the hole in the control arm, and another ring large enough to sit under the arm and receive the bushing as it is pressed through. Same deal to press the new one in.
I just looked in my info and it's practically worthless. Guess how I find the tools I need...
Old May 16, 2016
threeoten's Avatar
Is this inner ridge part of the bushing that I want to press out or is this part of the actual control arm?
Old May 16, 2016
Colin42's Avatar
compare it to the new bushing?
Old May 16, 2016
threeoten's Avatar
The new one is still in shipping. Just wanting to get as far as I can before it comes I guess.
Old May 16, 2016
Yes your arrow appears to be pointed at the outer ring.
The rubber was bonded to that ring.
NOTE the bushing has to be oriented a certain direction, the gaps in the rubber have to be in certain places. Use the originals as your guide if possible, mark positions before removal and mark the new in the same place (see your FSM)
(tool link: http://www.autotoolworld.com/Schley-..._p_168860.html)
Hey look at the pics in this thread too: http://9thcivic.com/forum/threads/can-9thgens-use-8thgen-aftermarket-compliance-bushings-i-have-the-answer.11428/
Old May 18, 2016
threeoten's Avatar
I started taking the old one out before marking it. I assume it's just the same positioning as the other side, just inverted, right? Also, do I want to grease the new one before installing? it's OEM, not poly.
Old May 18, 2016
Yes
No.
Install it dry.
sf170089
15
Feb 14, 2018 04:30 PM
Jade03CivicEX
26
Jun 11, 2016 02:38 PM
tonyguns
May 11, 2016 09:10 PM
norcal89451
Apr 21, 2016 10:44 PM
David DeMaio
Apr 21, 2016 03:40 AM
