2002 EX Suspension Restoration
Old May 22, 2018
mwhit0's Avatar
mwhit0 is an unknown quantity at this point
So I'm soon about to tackle a s**tload of mechanical 'rejuvenation' on my '02 EX 1.7 (ES2), I'm hoping I'm A. In the right place, B. Some of you may be more familiar with the suspension of the 7th gen (4-door, hopefully similar enough to the 2-door/EM).
The front, I can handle: ball joint in the knuckles, bushings clear-as-day in the LCA's. Now the rear...oh baby...
Chiefly, I'm wondering somebody may be able to point out what the names of the bushings I've encircled in chartreuse-y lime-green (if they are all indeed bushings), as I've only found (on RockAuto, PartsGeek, etc) the bushings for the rear UCA--doesn't seem the ES2 has a rear LCA(?) But what I assume is a drag link/trailing arm on the rear, the LCA-looking thing on the bottom, that connects to the rear knuckle, seems to have at least one forward bushing, and possibly a rear bushing on that rectangular connecting member. Am I missing anything here? (Appreciate any feedback, all you guys have been great in the past)
(Sidenote: if there's a better subforum/website to ask this, redirection would be greatly appreciated)
ID:	112237   Click image for larger version
ID:	112238   Click image for larger version
Old May 23, 2018
Slumpertcivic's Avatar
Re: 2002 EX Suspension Restoration
Why does your car look like it was sunk at sea for the last 16 years...
Maybe check local junkyard and see if you can find any that are less covered in barnacles erm rust..
Old May 23, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Rear upper and lower control arms.
See this illustration for part numbers... https://parts.sonshonda.com/showAsse...rimLevel=15706
Old May 23, 2018
mwhit0's Avatar
Welcome to the Rust Belt...I didn't know anything about buying a car when I bought it. Believe by it or not that muffler in the background is roughly 6 months old and "stainless"
Old May 23, 2018
GolNat's Avatar
Prelude Owner
Check energy suspensions website also for what bushings can be replaced. That link for the OEM parts will tell you what everything is.
The part in the first picture is the camber arm (UCA) and I am not sure if the bushings are replaceable. Other part is lower control arm which does have serviceable bushings.
Old May 15, 2019
Matt Bachand's Avatar
Matt Bachand is an unknown quantity at this point
I live in Mass where we salt heavily and my 8 year old stainless muffler looks nothing like that! It looks dirty but rust free...
GabberHead
Suspension
Jun 22, 2021 05:14 PM
johndeerebones
May 22, 2013 01:57 PM
hotrod_714
Jan 12, 2012 04:46 AM
chopper202
Mar 30, 2007 04:46 AM
WannaBFast
May 23, 2004 06:52 PM
