rear lower control arm bushings?
Old May 23, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well i got my suspension checked out cause i was getting vibrations.. which turned out to be just my tires improperly balanced, but they found that my rear lower control arm bushing is shot... its the bushing where alignment bolt is...
soo.. looks like a good reason to upgrade to poly bushings
i have 52k miles on my car, 20k is from my lowered suspension..
and i think energy has bushings but not sure if it comes with the one i need... anyone know?
Old May 23, 2004
robbclark1's Avatar
Retired suspension supermod.
Yes it does. There are 3 different sets of bushings. Two attached to the brake hub and one attached to the car. The hardest one to change is the one attached to the car. The other two are fairly simple. I can give you the DIY a shop wrote up when changing the rear bushings. You just need to go to home depot for some washers, nuts and a long metal threaded pole. ES does make a set.
ES Part number = 16.3118
http://www.energysuspension.com/artpg1.html
You need the ones on page 4 pictures 41a, 41b and 42. They aren't that hard to change. I have done them.
GolNat
Sep 10, 2015 08:25 PM
beachglass
May 22, 2015 09:59 PM
bryden13
May 18, 2015 12:22 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
