Noise on Neuspeed Race
Old Aug 15, 2003
tzeus's Avatar
tzeus is an unknown quantity at this point
I have a 2003 civic coupe and lowered with Neuspeed race springs paired with Koni Shocks. I've had it lowered for a few months now. At first I got it lowered, everything was fine, but now there's this annoying noise when i make a turn (sounds like the springs are loose) It does not make any noise when cruising straight on a very good road though. Anybody know what I need to do to get rid of the annoying noise??Should I get a new springs?
Old Aug 16, 2003
robbclark1's Avatar
Retired suspension supermod.
might need coil wrap. IT is a thin sheeth that goes around the bottom of the coils (where they all are touching) to stop them from grinding together.
Old Aug 16, 2003
Ag2Si's Avatar
Ag2Si is an unknown quantity at this point
I am getting a similar noise too after using H&R 2" drop springs and Koni yellows. To me it almost sounds like something in the steering linkage is binding. I mainly hear it when hitting a bump or grade change with the wheels turned.
Old Aug 16, 2003
tzeus's Avatar
What's a coil wrap? Where do i get them? Any pictures?
Old Aug 16, 2003
robbclark1's Avatar
coil wrap looks like this
Do a google search for it.
Old Aug 16, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
haha same stuff u can get at radio shack for cheap..
Old Aug 17, 2003
tzeus's Avatar
Does anybody use this coil wrap?Tell me about it, does it really work to get the noise away? How do you install them? Do I need to take the springs out? I just wanna make sure I'm getting the right stuff. Thanks for all the help!!!
Old Aug 17, 2003
robbclark1's Avatar
Yes you can get it at radio shack for cheaper. Yes people use it, yes it works, and i believe you have take the spring out.
Old Aug 18, 2003
Alex1's Avatar
If you read your Neuspeed manual it will tell you that it is supposed to make that noise. The cause is that the springs are shorter than stock so when the shocks travel up and down, the springs bounce up and down due to bumps, force, or if a person has blown shocks, the top perch hitting the top of the springs.
Old Aug 19, 2003
HYPR DRV's Avatar
Since 1977
HYPR DRV will become famous soon enough
Coil wrap has been tested, tried and true man!!! Go to Radio Shack, slap down 3 bucks and take care of the noise easily DIY. You don't need to take off the springs to stop the creaking noise. Just jack up the car until you can get some decent space in between the spring coils and slide the coil wrap (cut about 3" off) around the bottom coils. Slide it down as far as you can, practically until it hits the bottom perch. Lower the car and the noise will be gone, cuz' you just provided a buffer between the coils so they don't grind together when you turn the steering wheel. IT WORKS!! Now, to get rid of clanking noises when your car hits a bump, you WILL need to remove the springs, unless you can just deal with the noise. Not causing any damage, just annoying. Should you decide to do this, you need to remove the springs and wrap the VERY BOTTOM COIL with the rubber isolator that should still be adhered to the bottom of your stock springs. Rip it off the stocks and then just slide it around the aftermarkets. This rubber stops the metal springs from clanking against the metal perch that it sits in every time you hit a bump. All noises should be gone.
Old May 18, 2004
RiCeMaN's Avatar
RiCeMaN is an unknown quantity at this point
What are rubber isolator and where do I get them?
Old May 20, 2004
RW_Blaze's Avatar
RW_Blaze is an unknown quantity at this point
radio sahck have them? what do i say when i go there.. i need a coil wrap LOL... or is there a specific name or brand of it in radio shack so i can walk in there and juss pick one up with no question asked..
Old May 21, 2004
HYPR DRV's Avatar
Since 1977
Yes, Radio Shack. $3.00. Go in and look for it on the wall or just ask for a plastic cable wrap. You'll have to cut it cuz' you only need about 3" per spring. They're used to wrap electrical cables and stuff like that, but they will fit around your springs. Remember to wrap the dead coils. Push it down and around the springs as close to the perch as possible.
BTW: This thread is 9 months old and obviously no one read the post I made about this back in August.
Old May 24, 2004
Diablo's Avatar
Diablo is an unknown quantity at this point
I have the sane problem with my H&R and Koni yellow setup i was told that the bearing that sits on top of the spring are bad. (front)
Valkman
Aug 13, 2015 04:19 PM
bizspeed
Florida
Jul 14, 2015 08:40 PM
