Suspension upgrade; Poly vs. Rubber
So i'm going to be doing a complete suspension overhaul here within the next few months and i have been looking around but haven't really found to much information on this. my question is weather i should go with poly bushings or hardened rubber. also with the rear trailing arm bushings the spherical as well. I live in Utah so i have pretty harsh winters so there is lots of road salt and pot holes after the winter. This won't be a track car but a daily driver that i auto X. some of the points that i would like to be hit on is longevity of the two, maintenance, ride quality, and ease of installation. i have heard that with poly that they require pretty regular greasing to prevent squeaking, also they can do whats called binding up? not really sure what this is but it doesn't sound good. and looking at a couple of specific bushing replacement walkthroughs it seems like rubber ones have a metal casing around the bushing unlike the poly's. would pressing the bushings back in be a requirement with rubber? as far as the spherical rear trailing arm bushings i have no idea about anything with these ones and would like to know how they compare with the others and if their even practical with everyday use. also just to add for my set up i plan on going with the koni yellows with the eibach pro-kit springs and the asr subframe brace with a 21 mm rear sway bar. not sure with that stiff of suspension which would respond and hold up better as well.
Last edited by hotrod_714; Jan 9, 2012 at 12:42 PM. Reason: forgot to add information.
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Re: Suspension upgrade; Poly vs. Rubber
Poly will give you a stiffer ride and you will be able to feel the bumps a bit more..I have also heard in colder weather you will have to grease them or they squeak, I have also read people that give them good reveiws...I would just go with OEM but that is just me..
Some more infor on poly..but kinda one sided review
http://www.ehow.com/list_6928814_rea...-bushings.html
see i always thought poly was better up until i started digging and it seems like there are alot of mixed reviews about them. what exactly is it when they "Bind" up and hop out of a turn? also that review you posted says they're virtually maintenance free but from all the other forums that i have read that is not the case. I guess the main question i have is which one will last me the longest and have the least amount of up keep. I'm not necessarily worried about the ride quality, because I know its going to be stiff regardless. I just want it to be legit and last and give me 0 to as few of problems as possible.
Yea that reveiw seems to be favoring poly...i would just get oem.. here is an article against poly..
Suspension/bushing bind:
Bind occurs when the the pivot points of the suspension cannot move as intended. As it relates to third- and forth generation F-body car, bind is when the pivot points do not move smoothly under load (stiction, or static friction) or when the suspension moves outside its (or one or more of its components) design parameters (in this case, range of motion restricted by the lack of compliance in the polyurethane bushings)
Under hard cornering, bind can create dangerous handling conditions.
Polyurethane bushings:
Polyurethane (or 'poly' or 'plastic') bushings are popular, as they noticeably 'tighten up' the suspension, and the aftermarket arms look cool, but most purchasers to not understand how they work, or the problems they create. This is an old issue, but the recent popularity of poly-equipped aftermarket control arms has drowned out the proven drawbacks of this material, including stiction, binding, squeaking, harshness, and need for regular greasing.
Poly is used in place of the rubber portion of the factory bushings. Unlike the rubber bushings, they are not bonded to the inner and outer sleeve, and movement of the control arm will cause the internal surfaces of the sleeves and bushing to slide to accommodate the shearing forces. The two main issues:
Stiction (Static Friction): Under light loads, they may squeak as the arm moves. Regular greasing reduces the squeaking, but under high loads, especially cornering on uneven pavement, the "sticky" properties of polyurethane causes the plastic to "grab" the steel liner, adding harshness to the ride, as the steel sleeves can't slide smoothly over the poly bushing surfaces. At worst, when the suspension then cannot move as designed, the handling of the car will be affected and this can create unexpected and dangerous oversteer.
Binding: To complicate matters, the trailing arm type rear suspension in the late model f-body cars has bushings that flex or 'deflect' as a normal and required part of their function. As the solid 'live' axle moves to comply with an uneven surface, it (and the LCA mounting points) rotate in relation to the chassis.
Alternatives:
Why isn't Polyurethane a good bushing material?
Wheel hop: I mention it here because many have commented how poly bushings have 'cured' their wheel hop problems. Wheel hop occurs when the traction and torque applied to the drive wheels overwhelm the ability of the suspension to keep the tires on the ground. The tire grabs, deforms, 'hops' up and comes down to grab again (and again, etc), with some forward/back motion as allowed by the bushings. As the bushings degrade over time, the problem worsens -- which is why 'upgrading' to poly seems to help, as the basic factory bushings can be worn out in as little as 30K miles. Serious racers will go to rod ends, but for the street, to avoid the problems with polyurethane, the longer-lived 1LE bushings will suffice. From my research and experience, good quality adjustable shocks can play a big role in eliminating wheel hop, as well as Air Lift air bags installed in the rear coil springs, which also allow preloading of the right rear tire at the strip.
- The factory rubber bushings in the lower control arms accommodate this rotation/twist by design;
- Poly bushings force the lower control arms to twist.
- Tubular or boxed control arms - with poly bushings - force the LCA mounting brackets on the chassis and axle to bend;
- Now that the car relies on twisting metal for suspension, it may at times bind, as the axle cannot move smoothly comply with bumps. The resulting oversteer condition can result in loss of control on high speed corners - not what you want in a high-power rear-drive car.
- Subframe connectors (SFCs), added to brace the chassis, reinforce the forward LCA mounting points, but the twisting force is still there on the arms and rear mounts; poly bushings may seen to ride firmer after the addition of SFCs due to the more solid mounting of the LCAs.
- Even for lower speed handling, the poly bushings increase the rear roll stiffness - something you should be tuning with the spring rates and sway bars.
- Greasing the poly bushings does not help this issue.
Alternatives:
- GM factory 1LE LCAs and PHR with higher durometer (firmer) rubber bushings. If you don't have a 1LE Camaro/Firebird (or earlier SS/WS6), the parts are available from GM parts counters, GMPartsDirect, SLP, and others. Don't pay extra for boxed versions of the factory parts. Reference: 1LE Part Numbers (Note: GM discontinued the use of 1LE bushings in the WS6 and SS packages a couple years ago, so may/may not apply to your car)
- Spherical bushings - very noisy, harsh, meant for race cars. No deflection or stiction problems, but can loosen and rattle with wear over time.
- "...virtually no deflection..." (cut and pasted from their web page). As mentioned above, the engineers that design these cars employ rubber bushings because deflection is required in most locations.
- "But I lubed them well, or I used PolygraphiteŽ bushings": You are asking the poly material to act like metal bushings, and it can't. Lubing will temporarily reduce the squeaking and stiction. The graphite-impregnated versions are just 'pre-lubed', and once the graphite has worked its way out, the bushings will squeak and require regular lubing like the others. Lubing does nothing for the binding problem.
- "They get quieter over time": Poly will cold-flow, meaning it will deform under pressure and not return to normal, as it lacks the elasticity of the rubber bushings. Over time, they will loosen and then rattle. Check out the shape of your swaybar's poly end-link bushings after only a few months. This cold-flow issue can also lead to alignment problems on the front control arms, as the bushings deform.
- "But everyone sells them". Well, yes, and the manufacturers of Slick 50 and the makers of 'ultra/super white' bulbs could line up a long list of satisfied customers, but what would that mean?
- "Testimonials are everywhere!" but they don't convey the facts. Don't' believe everything you read in a glossy brochure or web page. Ever watch those late night infomercials? Like those other automotive miracles, wouldn't the large manufacturers pick up on this stuff if it really lived up to all it's claims?
- "But lots of other people use them!" As mentioned above, trailing arm suspension requires deflection in order to work, and when poly bushings are used, the required deflection is still there -- in the bending of the arms, mounting points, and flex of the rear tires. This is why these bushings appear to work fine for street applications.
- "They are just stamped steel". They are more than strong enough for a 1LE car on R compound tires. The stress loads are all longitudinal. They do not support any side loads, so they don't need strength in those directions.
- "They twist, especially with poly bushings in place." Of course - if you take out the bushing compliance with poly, something must give. This twisting does not effect the alignment or placement of the rear axle.
- "Boxed arms are better". There is no gain to be had from boxing the factory lower control arms. This is done by welding flat plates on the underside of the stamped steel arms. If fact, allowing them to twist will compensate for the poly bushings if you have them.
- "Boxed (or rectangular) tubing will resist lateral loading better than tubular". There are no lateral loads on the LCAs or PHR.
- "Tubular arms are stronger". Tubes are the strongest design for resisting twisting forces - but since this is not a problem in F-body trailing arm setups, tubular arms should be purchased for:
- appearance - 'cuz they look cool
- added weight (some can be heavier than stock/1LE)
- aftermarket LCAs with spherical bushings (for racing)
- adjustable aftermarket LCAs with spherical bushings (for racing, FWIW)
- spending excess cash.
arm, bushing, bushings, civic, daiybdriven, good, hard, honda, poly, polyurethane, rear, rubber, stiffen, suspension, trailing
