Squeaking From the rear tire areas
Old Oct 5, 2015
Nalmonte's Avatar
Nalmonte is an unknown quantity at this point
Hello All,
I have a 2001 Honda Civic ex coupe: I recently (July) had four all new strut assembly installed. Now from time to time both rear wheel squeak as if they need oil. I believe the Trail bush might be shot or another set of bushings back there. Has anyone else had this problem? if so what was the fix for you?
Thanks in advance.
Old Oct 6, 2015
Poopies's Avatar
Super Moderator
Re: Squeaking From the rear tire areas
When do they squeak?
Old Oct 6, 2015
Squeak every time you pump the brake pedal?
Old Oct 8, 2015
Nalmonte's Avatar
Poopies And Ezone,
Not all the time but for when I travel over bumps and potholes in the road.But there has been times where I go over bumps and potholes and I hear no squeaking. Never while I brake.
Old Oct 8, 2015
https://www.civicforums.com/forums/4...x-squeaks.html
There's an old bulletin for rear squeaks, bushings, but IDK if the link in that thread still works.
You may need to have someone bounce the car while you listen from underneath with a stethoscope
LionSpratt
Jan 29, 2017 11:07 PM
ChristinaVHH
May 10, 2015 03:51 PM
Jessica Leung
May 5, 2015 05:12 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
Bartkat
20
Feb 19, 2002 01:29 PM
