Suyspension feels way too hard going over speed bumps
Old Nov 4, 2019
Rebeljah's Avatar
Rebeljah
Rebeljah is an unknown quantity at this point
2005 LX Coupe - 151,000 miles
When going over speed bumps I literally have to slow down as much as possible or else it feels as if I hit a pot hole instead of a speed bump. Is that normal in a civic? Is there any inspection I can do to see if there is a problem with my suspension?
Old Nov 4, 2019
GolNat's Avatar
Prelude Owner
Re: Suyspension feels way too hard going over speed bumps
Did you just buy the car? Is the suspension OEM or original?
Old Nov 5, 2019
typically that is the case when shocks are on the way out (or already out)
but do check before changing
Old Jan 10, 2020
Matt Bachand's Avatar
Matt Bachand is an unknown quantity at this point
I have the same problem with my 04 coupe with new struts..... I am thinking its the lower control arm bushings... I'm going to swap em out (the LCA's & balljoints) this spring and see if it fixes it.
lowther420
Jan 23, 2005 12:12 AM
LuZi0n
Jul 8, 2004 09:23 AM
WD40
Jul 9, 2002 12:54 AM
AlphaInfinity
17
May 9, 2002 09:25 PM
WhiteRabbit
Mar 12, 2002 04:15 PM
