lowering plus speed bumps = bad
i don't know how low i dropped it but when i go thru a speed bump i hear the bottom of my car scratching thru the whole way so i avoid as much speed bumps as possible, but if theres no way to avoid it i go in a diagnol and it don't scratch as much
Hey,
I dropped mine 2 inches.
I have scraped many times, usually its through blind bumps or dips. I rarely scrape the speed bumps, because I go diagional and really slow. I usually have the scrapes like I said through the blind areas, where I rarely drive.
But for the most part, going the same route everyday, I have marked all the hazards and avoid them.
Ray
Ray
<< Has anyone else noticed that their car rattles more after every mod thats done? >>
actually, this can be a big problem with DIY'ers who dont take caution with panels. The plastic trim inside our cars are held on by clips, and when you remove the pieces, you need to make sure all the clips came with the trim piece, and are not stuck on the car. Also, when you put the trim piece on, you need to make a mental note of where each clip is, and then apply pressure (pound [IMG]i/expressions/face-icon-small-smile.gif[/IMG] ) on the trim piece where the clips are, to ensure they seat.
my car is lowerd a little more than 2 inchs with ground control coilovers. the front scrapes all the time when i pull out of my driveway. i don't like it scrapeing any more so i will raise it up a little when i get my body kit. another thing about lowering or car this low is that when you get your oil changed, your car might not fit on the jack.
<< another thing about lowering or car this low is that when you get your oil changed, your car might not fit on the jack. >>
wouldnt want to find that out on the side of the road with a flat tire
i have no wheel gap thats about as much info i can give you...as for having a flat tire and not being able to jack your car up its true...so all you gotta do is find a piece of 2x4 wood and drive on it so your car will be higher so you can fit the jack under and jack your car up...
Im not sure how many there are in the states, but here in canada, all of our speed bumps are being changed to "speed humps". its like a little hill you have to go over, and its long enough that by the time your front tires reach the end of it, your back tires have just begun to go over it. it saves the bottom of my car even since i dropped it 2".
DIY King
Air ride suspension is the only way to fly IMO. That's what I'm gettin', !@#$. [IMG]i/expressions/laugh2.gif[/IMG] ::in the voice of the barber from Coming to America::
mrohitredd
May 28, 2015 10:03 AM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
