New 2002 EX owner here
Old Jan 19, 2020
SKcivic's Avatar
SKcivic is a jewel in the roughSKcivic is a jewel in the roughSKcivic is a jewel in the rough
2002 Civic EX Coupe, Automatic.
Background - $500 car, with no maintenance records & 167000 miles.
Engine maintenance was just completed by my technician.
Next on the list;
- replace the Front Upper Strut Bearing Plates, the rubber bushings are blown out.
- replace the Front Lower Control Arms, the rubber bushings are blown out.
I'm planning on replacing the strut assembly from Detroit Axle.
I'm planning on replacing the lower control arms & upgrading to a "Red Stiffer Bushing." (the roads here suck in Korea)
I'm planning on installing two new Timken wheel bearings.
Would you recommend I purchase hubs also, when doing the wheel bearings? Do the hubs & bearings usually come apart pretty easily?
Any recommendations on better parts? Anything else to consider?
Thank You
- SKcivic
Tyler Clark
Nov 22, 2019 08:35 PM
exturbo6
Aug 17, 2006 08:41 AM
exturbo6
Mid Atlantic
19
May 17, 2006 07:05 AM
Blk4blk2K1
Florida
94
Jan 26, 2006 07:39 PM
noVICe
Chicago
114
Aug 11, 2005 10:55 AM
