Greaser with joints
Greaser with joints
OK. I searched all over the forums and I see conflicting information and a bunch of old thread so I’m asking it here.
what kind of grease goes in the ball joints tie rod ends and sway bar mounts. I got an aftermarket kit from Detroit axle, no judgment please. This car is 20 years old already. I just don’t want to make the stuff deteriorate faster than necessary.
i’m seeing NLGI number two seems to be the right stuff. I called Detroit and they went online and looked it up, no real help there.
Re: Greaser with joints
Genuine Honda replacement ball joints and tie rod ends don't have grease zerk fittings, no way to add the wrong grease.
If installing aftermarket, ordinary chassis grease in a grease gun.
Rubber sway bar bushings? Hondas bushings were installed dry.
If you meant aftermarket sway bar links with grease zerks, use the same chassis grease.
the ones that are specific are the ones to be careful. The transmission fluid in the 7th gen are engine oil grade... very low viscosity. yeah, i was surprised when i saw in the owners' manual.
you can get yours here
power steering was tricky too?
Thanx. I got prices from the dealer for the ATF and power steering fluid, no big deal there. My 96 civic manual, I probably went 500k miles and changed the transmission flui maybe four times? I might’ve gotten another 200k if I did it more often. Oh yea, never changed rear brakes nor clutch either. ‘‘Twas a little beast.
2004 Honda CIVIC EP3 2.0L 4-cyl Engine Code K20A3
LUBRICANTS & FLUIDS:
Manual Transmission,NRH3 (5-SPD)......GLS42 [1]
All TEMPS......
Manual Synchromesh Transmission Fluid 5W-30 (MTFQT)
TYPICAL TECHNICAL PROPERTIES
Synthetic Manual Synchromesh Transmission Fluid (MTF)
This Manual Synchromesh Transmission Fluid has (VI) Viscosity Index of 196, I believe this is the highest performing Transmission Fluid for this application that I have found or may be available anywhere. It is designed to be compatible with yellow metals ie Brass Copper found in Synchromesh Transmissions
LUBRICANTS & FLUIDS:Manual Transmission,NRH3 (5-SPD)......GLS42 [1]
All TEMPS......
jmonty0523
Mar 17, 2015 10:15 AM
jonnyl888
Jan 13, 2012 07:06 PM
p8nt
Jun 26, 2011 08:37 AM
petersaxle
Apr 24, 2011 07:03 AM
