Replaced ball joints, still sound bad
Old Apr 2, 2011
p8nt's Avatar
p8nt is an unknown quantity at this point
I just replaced the ball joints on my 01 since they sounded like they were about to grenade evertyime I hit a bump. The car definetly feels tighter when driven, and although the noise is better, there is still a definate "clunk" in the right conditions.
Something else I should be looking at?
Thanks!
Old Apr 3, 2011
Re: Replaced ball joints, still sound bad
most common ones: sway bar endlinks, compliance bushings in LCA's, tie-rod ends, strut top hats,
others: etc
Old Apr 3, 2011
MelJ's Avatar
Trance Addict
Lol. Oh god. That reminds me. My girlfriend's car would clunk every time she hit a bump. Her noise actually did turn out to be the tie rod ends. Some asshat put electrical tape around the boots. Didn't help. I took them off last night and there was grease everywhere. Sway bar endlinks, especially the OEM ones, aren't that tough. After 10 years, they break pretty easily. Trust me, I know. Lol. sdaidoji gave a good place to start looking.
Old Apr 3, 2011
Yeah, but i forgot to add the engine mounts in the most common ones
Old Apr 4, 2011
p8nt's Avatar
Today while driving I hit a bump and could swear I felt the "clunking" through the floor board against my foot. Does that narrow the list of potential problems?
Old Apr 4, 2011
? uncommon cause? exhaust? something got under the car?
Old Apr 30, 2011
bigheadmark's Avatar
bigheadmark is an unknown quantity at this point
what does the "top hat" look like? the reason I ask, is becuase I am getting a clunking noise coming from the front end even though i replaced the tie rod ends, lower ball joints, and sway bar end links...the lca bushings appear to be in good shape..the struts appear to be in good condition.....I pulled apart one of the struts, and noticed alot of sand under the "bearing" ( I guesss that's what it's called, even though there are no metal bearings in it...) cleaned it out and regreased....about to check the other side ...also, how can you tell when the strut mount, part # 51920-S5A-024 goes bad?? I noticed there's a bushing inside of it...it appears to be in good shape
Old Apr 30, 2011
they not that expensive.
top mount is top mount, where the bearings are
Old May 12, 2011
p8nt's Avatar
So today this arrived at my house.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
LCA bushings are the main problem, but ill do the rest while im in there, minus the tie rod ends if they look ok. Will an alingment be needed if I can get by without touching the tie rods?
Any advice or tips?
Thanks for all your help thus far!
Old May 14, 2011
stevelaw18's Avatar
stevelaw18 is an unknown quantity at this point
Any advice or tips?
Did you get the parts installed? That's a good deal, are they OEM? I was originally going to install the Energy Suspension bushings in my current LCAs, but they are pretty rusted, so it may be a better idea to replace the entire LCA.
I'm pretty sure you'll be fine without an alignment as those parts are not intended to be adjusted.
Old May 14, 2011
if changing the top hats as well, might be advisable to align. LCA's - if the older ones were somewhat bent, the new ones could change alignment too.
Old Jun 26, 2011
p8nt's Avatar
Not OEM, but fitment was perfect. Replaced everything but the tie rod ends. Car feels much better and the noise I was hearing is long gone. However now I notice a slight wheel bearing hum (no noticeable play in the wheels yet) and a repetitious creek/groan while braking. (brakes are completely new, except for front calipers)
I suppose I cant complain as Ive racked up 232,xxx miles at this point. Automatic by the way!
pheaton
May 4, 2015 08:26 PM
bsmiley
Apr 27, 2015 01:27 PM
El_Spic
Apr 23, 2015 03:14 PM
thesushiboy
Apr 12, 2015 02:54 AM
01civicboi
Nov 18, 2001 04:39 PM
