Could a dirty bead be causing slow leaks
Old Mar 15, 2025
Robertlx's Avatar
Robertlx is an unknown quantity at this point
Could a dirty bead be causing slow leaks in my two rear wheels on a 2005 Honda civic LX sedan. Both rear tires every now and then start losing pressure. I noticed the tires being flatish at about 20 psi. The rims could be the culprit somehow maybe bent but any other rim reasons I've never heard of..and of course the valve stems.. they're probably pretty old but I checked it with soapy water and found no bubbles. Any suggestions
Old Mar 17, 2025
Colin42's Avatar
Re: Could a dirty bead be causing slow leaks
You should get bubbles from the bead. Might be the inner bead
Old Mar 17, 2025
Robertlx's Avatar
The rear tires lose air every now and then..just out of nowhere
Old Mar 19, 2025
Colin42's Avatar
Take it to a tire shop if you cant figure it out
Supertech
Feb 21, 2016 05:14 PM
gearbox
Buy, Sell, & Trade - Archive
Jun 22, 2008 01:56 PM
nookiemonster
19
Apr 25, 2005 07:26 PM
blouisgod
Jan 10, 2003 10:12 AM
locozoko
Nov 4, 2001 08:44 PM
