2001 Civic front end clunk when accelerating from stop, heavy braking [solved - info]
Old Nov 8, 2022
TKA Dave's Avatar
New Member
TKA Dave is an unknown quantity at this point
Cool 2001 Civic front end clunk when accelerating from stop, heavy braking [solved - info]
I started noticing the clunk after I had the subframe out of the car when changing the transmission input shaft bearing. A year later, and after replacing nearly everything in the front end with no success, I finally found the issue. Apparently the subframe should be tightened with weight on the tires, not when jacked up. I loosened the 4 -17mm bolts holding it, let the car off the jack stands, then tightened them back up. Clunking is finally gone! Another thing I did was make sure the sway bar was aligned correctly, equal distance from the control arm on both sides – loosen the 2 bushing brackets and use a pry bar to wiggle it left or right as needed. Hopefully this helps someone before replacing everything like I did. I even paid a mechanic to diagnose the noise, he had me replacing parts unnecessarily.
Old Nov 8, 2022
FRSam's Avatar
Click Here
re: 2001 Civic front end clunk when accelerating from stop, heavy braking [solved - info]
Thanks for posting. The rest of them were redundant. For future reference, one post is enough.
Anthony_76
Jan 1, 2013 08:30 PM
shawnmd
May 4, 2012 10:09 AM
kiwi133
Apr 11, 2004 03:22 AM
kenji4861
Nov 8, 2003 12:50 PM
Lek
Jun 19, 2003 07:34 PM
