lower ball joint 03 civic ex
Old Jul 16, 2016
03hOnDa's Avatar
03hOnDa is an unknown quantity at this point
Exclamation lower ball joint 03 civic ex
hey everyone im new to the site,
im about to tackle a lower ball joint replacement and im looking for some advice I do all my own maintenance fluids,belts, brakes, and ive changed the alternator so I feel very capable Im going to rent the press and I have the replacement part, I heard the separator is not nessecary but im not 100%, some firsthand experience is priceless. need help the shop wants 400 and im trying to avoid the $
Old Jul 16, 2016
Re: lower ball joint 03 civic ex
Be careful. Read the service information. Read the TSB information linked in post #2
https://www.civicforums.com/forums/4...er-assmnt.html
Old Jul 18, 2016
03hOnDa's Avatar
Thanks ez one,
I read the post it helped a bit. I'm gonna have some old gear heads assisting I'll just do most of the work my main question is in rebuilding when I get the ball joint out(if all goes according) is it pressed to the knuckle or lac, I've seen were you can remove the knuckle then press out and press in the new ball joint but im not sure how it fastens to the lca
Old Jul 18, 2016
03hOnDa's Avatar
*ezone
Old Jul 18, 2016
It's pressed into the knuckle, you should be able to see it in the effed up pics on the thread linked.
The tapered shaft fits into the LCA pointing down, and the nut threads on from the bottom.
Old Jul 18, 2016
03hOnDa's Avatar
*ezone
Old Jul 18, 2016
03hOnDa's Avatar
Thanks man that was one of my main concerns I saw a method where you jack up the lca and wedge a wrench in then depress the jack to pop the ball joint out other than I 2ould just use the press it seems pretty straight forward, I wouldn't atempt it if I wasn't confidant
Old Jul 19, 2016
mikey1's Avatar
this statement......
and this statement.....
contradict each other
Old Jul 20, 2016
03hOnDa's Avatar
Damn you should have been a detective thanks for your help bud
dan_has_a_civic
Aug 14, 2005 12:43 PM
winnerpl
Oct 19, 2004 06:44 PM
CivicBabe01
South
Mar 10, 2004 02:55 PM
OmegaBlue2k1
Mid West
Dec 10, 2002 09:28 PM
