Outer tie rod removal issue
Old Aug 29, 2019
Matthew Jackson's Avatar
Matthew Jackson is an unknown quantity at this point
I'm trying to replace my outer tie rods but it seems stuck I got the lock nut loose and it's able to spin around but I can't take out the actual joint itself out having a real hard time please help thank you 🙏
Old Aug 30, 2019
Slumpertcivic's Avatar
Re: Outer tie rod removal issue
So you removed the cotter pin, and removed the castle nut and now it’s just stuck?
Whack the side of the knuckle right where the tie rod pin goes through it with heaviest hammer you have a few times. It should pop right out.
Old Aug 30, 2019
It's off the strut but the outer tie Rod is still connected to the inner and it's stuck.
Old Aug 30, 2019
BrotatoChip's Avatar
Super Moderator
Same thing happened to me, over the years they had become fused together basically. I ended up just replacing the inner and outer at the same time.
skoot
Nov 26, 2007 03:40 PM
HondaNation
Jul 16, 2005 07:49 PM
2002excpe
Jan 16, 2005 01:37 PM
matrix311
Jun 16, 2004 01:40 PM
Aznnp77
Aug 22, 2003 09:45 AM
