Bearing + Caliper
Bearing + Caliper
So, i had my car checked, and my front bearing is on its way out, i've found a replacement one on eurocarparts, but are they any good, are they worth buying?
Also my front right (drivers side) caliper is starting to seize. Are the rebuild kits too much hassle to do, or am i just better of buying a new caliper from eurocarparts, again, are they any good or should i go elswhere?
Also, does anyone know the size of the nut for the hub in the middle, is it 32mm or 36mm?
Thanks!
Thanks!
Re: Bearing + Caliper
Why are you buying parts for a Honda on a euro car site?
new/rebuilt calipers are pretty cheap...
Should be 32mm for the axle nut, buy a new one and don't forget to restake it
Ah ok that makes sense, yeah most people on here are in the US, I'm in Canada
What brands are the parts you're looking at?
Never heard of pagid, and "aftermarket" could be good, but probably not...
Check rockauto and see how bad shipping to the UK is?
Or see if Amazon has those parts.
How expensive are the local parts stores over there?
AMartin25
Jan 17, 2017 06:45 PM
OMega
Jul 28, 2003 05:05 PM
