Lower ball joints without alignment [solved]
Old Mar 15, 2025
Secret Tunnel's Avatar
Secret Tunnel is an unknown quantity at this point
I have a 2005 Civic and need to replace the lower ball joints, I have found/read the ball joint service TSB and determined the vehicle has the factory ball joints and not the oversized ones. My question is if I do not remove the strut from the knuckle will I need a alignment? It will be more difficult I realize but would save $140 since the alignment is currently good.
These are the sets I own for replacing the ball joints, if for some reason they wont work please let me know what I should get instead.
https://www.harborfreight.com/ball-j...EaApgQEALw_wcB
https://www.harborfreight.com/automo...ece-58785.html
Old Mar 17, 2025
Colin42's Avatar
re: Lower ball joints without alignment [solved]
If you're not unbolting it from the strut you should be fine.
Old May 19, 2025
Update, no problem with replacing the lower ball joints with removing the knuckle and strut as one assembly. It is heavier then I anticipated but not that bad, for pressing out the old and pressing in the new ball joints this kit was perfect but I did have to cut the old ball joint bolt portion off so the tool would fit.
Millsy088
Suspension
19
Dec 30, 2021 02:08 PM
maverickfhs
35
May 21, 2017 06:24 PM
woohoo321
Jul 14, 2012 11:18 PM
Demonicus666
Jun 8, 2006 10:31 AM
