Lower ball joints and outer tie rod ends replacement cost
Old Feb 29, 2024
Robertlx's Avatar
Robertlx is an unknown quantity at this point
2005 Honda civic LX sedan..sometime near the beginning of summer I would like to replace both lower ball joints and both tie rod ends upon advisement. Mechanic says boots have deteriorated too much. My question is here in U.S. what would the labor cost be to do both ball joints and tie rod ends at the same time.
Old Feb 29, 2024
Re: Lower ball joints and outer tie rod ends replacement cost
not a performance modification - moving to mechanical issues section
Old Feb 29, 2024
Robertlx's Avatar
This is the private message I received..
Your thread "Lower ball joints and outer tie rod ends replacement cost" has been moved to Suspension (https://www.civicforums.com/forums/s...d.php?t=388409) by our moderator team. We encourage you to continue your discussion in this new location.
Old Feb 29, 2024
yes, you posted on suspension performance modification section, which is intended for aftermarket suspension upgrades such as stiffer springs and dampers, coilovers, etc, not stock replacement parts
Old Feb 29, 2024
Colin42's Avatar
It varies too much to ask here for prices. Call a couple of local shops for quotes, you'll need an alignment after as well.
Old Feb 29, 2024
I'd ballpark a few hundred bucks labor plus parts and maybe the cost of alignment
Dangerousjordan
Jul 28, 2015 08:24 AM
El_Spic
Apr 23, 2015 03:14 PM
dswami1
Jan 4, 2007 08:33 PM
acjones21
32
Mar 22, 2006 12:31 AM
Kraize2001Civic
May 24, 2002 12:51 AM
