Power Steering cutting out
Old Feb 4, 2020
Crunch Master's Avatar
Crunch Master is an unknown quantity at this point
Good day comrades,
Currently experiencing a weird issue with my 2003, 4 door, 5 speed manual civic.
Recently up here we had a 7 day cold snap of temperatures dipping down to -52 degrees Celsius (-61 F for you American folks). After this cold snap a new problem emerged on my vehicle. When turning going forward or backward at low speeds (and only at low speeds), I find the steering locks up and becomes stiff to turn intermittently (Still able to turn the wheel but it is much stiffer). Once I straighten the wheel the stiffness goes away.
Thoughts?
Old Feb 4, 2020
BrotatoChip's Avatar
Super Moderator
Re: Power Steering cutting out
Is the power steering fluid low? When was the last time it was changed?
Old Feb 4, 2020
Power steering is changed and full 👍
Old Feb 5, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
At minus 52 C I would stiffen up too!
Seriously, you should have fresh Honda PS fluid filled to the Max line the reservoir. Bleed air from the system. Any contamination or water in the system can affect performance.
After the car has warmed up, you should feel the PS retunr to normal.
gotcivicback
Jan 27, 2014 12:22 PM
swoody
Oct 15, 2013 05:45 PM
civicstylz4u
May 14, 2004 10:48 PM
CivicSouldjaEX
Mar 30, 2003 01:29 PM
