Bump stop split in half
Old Apr 22, 2016
threeoten's Avatar
threeoten is an unknown quantity at this point
Both front bump stops around my struts are split. The top portion is hanging where it should and the bottom half just sits down at the bottom of the strut piston. I imagine it would still do its job, or no? I'm about to change the struts, should I wait and order $30 for 2 bump stops?
image showing where it's split: http://screencast.com/t/iEFq3uJU
thanks
Old Apr 22, 2016
Poopies's Avatar
Super Moderator
Re: Bump stop split in half
If you take it easy on her, you should be good until the change if it's soon. No more 90mph speed bumps!
Old Apr 22, 2016
since you need to do the struts anyway, why not?
Old Apr 22, 2016
threeoten's Avatar
Because $30-40 and wondering if the old ones will still be doing their job just the same.
Old Apr 22, 2016
how much to redo if they fall off?
Old Apr 22, 2016
The large tube part (dust cover) falling off isn't necessarily a big deal IMO, as long as the upper part of mostly solid rubber that actually does the job of protecting from bottoming out the strut is still intact.
Old Apr 22, 2016
Lol, yeah, but just don't want the mindset of "I Got away that other time, maybe the tie rod and ball joint are not as important as the stops either "
Old Apr 23, 2016
threeoten's Avatar
I'll just run with the old ones I guess. Yeah, also the steering wheel fell off a while back, but I just threw a vice pliers on there instead. It works.
crazzywolfie
Apr 23, 2016 07:18 PM
threeoten
Suspension
Apr 23, 2016 04:00 PM
WolfmanAndrew
Apr 21, 2016 08:47 PM
Robert Campbell
General 7th Gen
Apr 19, 2016 01:58 AM
Timbogates
Apr 17, 2016 01:59 PM
