Grinding Noise After Strut Assembly Install [solved]
Old Nov 21, 2021
suspensionnoise's Avatar
suspensionnoise is an unknown quantity at this point
After replacing the strut assembly in my 2003 Honda Civic lx it makes a grinding noise from the driver-side every time the wheel revolves. I figured it was the dust shield, because the passenger side didn't have a dust shield and doesn't make a noise. Also I kinda crunched it when I jacked up the suspension to put in the pinch bolts. The shield was rusted to all hell so I tore it off with vice grips, but the noise is the same. Any ideas?
Old Nov 21, 2021
Colin42's Avatar
re: Grinding Noise After Strut Assembly Install [solved]
Keep looking, if it won't make the noise with the suspension at full droop you're going to have to load up the suspension to find the noise
Old Nov 22, 2021
BrotatoChip's Avatar
Super Moderator
There could still be a piece of the dust shield rubbing the rotor.
Old Jan 13, 2023
ksjung714's Avatar
ksjung714 is an unknown quantity at this point
Did you ever find a solution to this? Or did it go away naturally? I just replaced my struts with Coilovers and a similar issue is happening on my 02'.
Old Jan 13, 2023
yes, the alignment was out so bad the outer tie rod was rubbing against the tire. it made a noise once per rotation and was way worse turning one way than the other way. definitely don't wait for it to go away, check the inside of ur tire asap
bscappell
Suspension
Dec 23, 2019 11:34 PM
diggyd357
Jan 16, 2016 06:41 AM
mdwood2
Jul 8, 2012 05:05 PM
iamboo
Jan 15, 2005 12:42 PM
integ108
Aug 6, 2003 06:08 PM
