Rumble Strip Sound After Turning
Old Jan 23, 2019
robert bloomer's Avatar
robert bloomer is an unknown quantity at this point
After I turn the car, usually right turns and then straighten up and accelerate (especially after getting off an exit)
the car makes a sound like it's gone off a highway and onto a rumble strip. The vibration happens around 40-50 mph
and then stops when I get up to speed. Someone suggested to me that it was a bad CV axle, but it's not the
usual clicking sounds people with this problem describe. It's more of a vibration. A shuddering rumble.
The rubber boots don't feel broken but I can't really see them. Could this still be a bad CV axle?
Old Jan 23, 2019
Slumpertcivic's Avatar
Re: Rumble Strip Sound After Turning
Inner CV joints are known to rumble, also possible failed motor mount or control arm bushing can get “loaded” during the turn resulting in metal to metal contact and that growl.
Old Jan 24, 2019
mikey1's Avatar
C/V axle/joint
lower control arm bushings
wheel bearing
tires / broken strap/buldge
Old Jan 24, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
My guess is a bad front driver's side wheel bearing. Bad bearings will produce a hum sound.
Old Jan 24, 2019
mac25's Avatar
Dr Krieger of Modification
It won't be an Lca bushing those make a pop-pop sound while driving over bumps.
As stated above, if its while you are turning right that means the suspension is loaded on the left. So its most likely a left wheel bearing.
(if the CV boots are intact, then they should be fine).
seoul4korea
Aug 11, 2010 06:01 PM
Apollyon02ex
Feb 27, 2009 12:42 PM
05simplecivic
Feb 7, 2009 10:22 PM
tastyratz
Apr 10, 2006 08:10 AM
Da1lyDr1ver
Apr 10, 2005 09:51 PM
