sound when turning.. sometimes
Old Feb 18, 2009
Apollyon02ex's Avatar
Apollyon02ex is an unknown quantity at this point
alright, well sometimes... when i turn i hear almost a click or or a pop, idk how to explain the sound. but its only when turning, but only sometimes. kinda depends on how fast i'm turning or how sharp the turn is.
it sounds like its coming from the right wheel well area. i'll try and remember the sound next time it happens... but any ideas off hand?
Old Feb 20, 2009
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: sound when turning.. sometimes
are u possibly in 2nd gear when this sound occurs? i have the same problem with the clicking when i turn right in 2nd gear. im pretty sure its one of the bearings in the tranny. maybe the input shaft bearing i think
Old Feb 20, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Go to an empty parking lot, cut the wheel all the way, put it in first gear and go very slowly. If you hear the popping then it's your suspension, probably a CV joint or bad axle. It's a common test you should do before you buy a car, it'll tell you a lot about the front end.
Old Feb 20, 2009
vicaphit's Avatar
vicaphit is an unknown quantity at this point
Does the click just click once, or is it clicking throughout the turn. I had to replace both drive axles on my 97 civic because the boot wore through and dirt got into the knuckle for the axles. This wears down the axles, and makes the clicking noise. The speed of the clicking will correspond with the speed of the turn. Like DeX said, it could be the CV joint.
Old Feb 23, 2009
usually clicks once, and i think it happens with left turns... i can't recall a right turn were it clicked. and its just once and its much like a clank.. doesnt happen to often, like i said, right speed right angle of turn. i'll try that parking lot thing
Old Feb 27, 2009
civic-king's Avatar
civic-king is an unknown quantity at this point
it's your CV axle. i would not worry about it if the boots are ok. mike clicks on gradual right hand turns. the boots are fine, so no greese is leaking out. it's just a noise you will here from time to time. mine has been clicking for over 150,000 miles (02 civic 235,000 miles) with no issues. if you want to find a driveline shop in your area. they will replace cage, ball bearings, greese, and boot for about $50 per axle or less. but i would just let it go and save your money.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
