Problem strut replacement - drive shaft pulled out
I had problems with the a Gabriel strut not receiving the control arm after installation. After using a 1" socket to expand the strut connection, I discovered the drive shaft had pull out exposing some shaft beyond the seal. I cannot get the shaft full in even though the right wheel still turns when I tuen the left.
Any suggestions?
Any suggestions?
Re: Problem strut replacement - drive shaft pulled out
Drive shaft pulled out of the trans or pulled out of the hub?
Some joints use rollers with a pair of flat spots on each one, necessitating correct orientation before the roller can slide into its slot in the cup.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
smmahan
Apr 15, 2015 08:17 PM
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
