Tie rod lock nut keeps coming loose. Please help!
Old Jun 8, 2018
SD Civic's Avatar
SD Civic is an unknown quantity at this point
I have a 2004 Civic ex. Its stock but refreshed. The outer tie rod end links are new the inners are not. My problem is that the lock nut thats on the inner tie rod that locks into the outer keeps coming loose somehow. Ive noticed that when I'm backing up with the wheel turned it feels like steering is rolling over on itswlf, then the steering is loose and sure enough I go under the car and the nut is loose. Has anyone experienced this or know how to fix it?
Old Jun 8, 2018
Re: Tie rod lock nut keeps coming loose. Please help!
threadlock?
Old Jun 8, 2018
SD Civic's Avatar
Originally Posted by sdaidoji
threadlock?
Tried it
Old Jun 8, 2018
Slumpertcivic's Avatar
My first guess would be the metal is coated with something slippery.
Loosen the nut back a lot, spray heck out,of everything with carb cleaner. Let dry, spray again, put few drops red threadlock on the threads and should be good.
Old Jun 9, 2018
Got a picture pointing out the exact problem area?
If you mean the big (15/16") locknut that gets loosened to adjust toe, usually someone just didn't get it tight enough.
Matthew Jackson
Suspension
Aug 30, 2019 12:33 PM
17
Jul 23, 2015 11:48 PM
jr6784
May 16, 2012 09:25 PM
SevenCyrus
Dec 16, 2006 11:58 AM
matrix311
Jun 16, 2004 01:40 PM
