Sotck/OE Ride Quality
Old Dec 16, 2017
mwhit0's Avatar
mwhit0 is an unknown quantity at this point
Hope I'm in the right place.
I've got an '02 EX sedan with 124k on it, the suspension has me concerned. I'd like to think the wheels shouldn't land a foot away from where they leave the ground when I hit abnormalities in the road—bumps, cracks, potholes, etc., of which there are *plenty* in SW PA. I'm not interested in "slamming" the car, if possible I'd actually prefer to avoid lowering it at all, but given what I've gone over with a former mechanic I work with, sounds like time to lay the factory struts/springs to rest and replace them.
Some of the jargon I've seen around the web: koni yellows, tokico blues, pro-kit, tein s-tech, ground control, AGX. I'm aware these are all products, not sure if geared towards "upgraded performance" or otherwise, I'd really just like to restore the ride to near-stock quality, preferably without coughing up Honda's going-rate for genuine OE components. Anyone here have some input as to what I should be looking for?
Any feedback is appreciated
Old Dec 16, 2017
Re: Sotck/OE Ride Quality
Yeah, sounds like your struts are gone. The springs are likely fine. You'll notice close to stock dampening with tokico blues and you can put the OEM springs on those.
Old Dec 16, 2017
GolNat's Avatar
Prelude Owner
New KYB struts. Springs are fine unless they are broken.
Old Dec 17, 2017
Wankenstein's Avatar
Did you or a mechanic perform a shock/struts rebound test? (Google it)
Are the current shock/struts stock KYB's or on lowering springs?
I'm not sure if adjustables would go any higher than stock height? Maybe others here can confirm. Lifting it too high might compromise safety?
Old Dec 17, 2017
The adjustable height, aka coilover usually have the shock body shortened for lowering, so usually they can't even get to stock height.
As the others said, keep springs, change shocks.
They called strut in the parts store.
kayaba is equivalent stock.
Old Dec 17, 2017
Quick and dirty rebound test: push down on one corner of the car with some force and watch it for bouncing. If it bounces instead of almost immediately going back to regular height, bad strut. Repeat 3 more times, one for each corner.
Old Dec 18, 2017
mwhit0's Avatar
Yeah it's rocked side to side since I bought it. Particularly when larger vehicles drive by while I'm at a red light.
Old Dec 19, 2017
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Mine would keep bouncing on the highway. It became scary when it would bounce on the off/on ramps while turning. The back end wanted to get out while it bounced. That was when I changed them and also installed some springs for a mild drop.
Old Dec 26, 2017
mwhit0's Avatar
How did the ride feel in similar circumstances after you switched the struts/springs?
Old Dec 27, 2017
GusBuz's Avatar
Far better! Bounce was gone and I could take the on and off ramps without fear
jwsisme
Nov 11, 2002 11:08 PM
FastandFurious
Aug 23, 2002 12:04 PM
B
Jun 22, 2002 11:34 AM
Sampsonite
Jun 6, 2002 01:24 AM
iamfob
May 5, 2002 07:17 PM
