02 Civic Ex Steering Knuckles on 02 Si - Alignment?
Old Jan 24, 2022
7lucas8's Avatar
7lucas8 is an unknown quantity at this point
I had swapped the EX/EM2 knuckles into my EP3/Si, and I ordered some 16mm to 14mm reducing washers to make up in the bolt size difference. Now the problem is, my camber is crazy positive and I am wondering what the best way about straightening them out or even going more negative than OEM. From what I understand:
Coilovers would be the best route since I would be decreasing camber as I lower the car, I think I read about -.75 for every inch lowered. That, paired with camber plates would hopefully help me reach the -2 degrees overall I'm looking for. This would be the most expensive route and I also have other things in the car that need love, so cheaper would be better.
Lowering springs & camber plates may not reach the desired camber I am looking for (again, about -2). This would be cost effective.
Camber bolts wouldn't last more than a couple pot holes and make a negligible difference.
What would be the best way of getting the desired camber?
Old Jan 24, 2022
Re: 02 Civic Ex Steering Knuckles on 02 Si - Alignment?
  1. Why did you change knuckles? damaged?
  2. Why did you use EX/EM2 ones?
Old Jan 24, 2022
7lucas8's Avatar
Both bearings went bad on me and luckily(?) my EX just died on me so I decided it would be cheaper to swap them since they were still good.
Old Jan 25, 2022
since they are out,, take the knuckles to a machine shop and have the bearings installed, assemble them back to the car.
correct the source of the issue, don't band-aid what is wrong, it will mend in wrong ways
peimp
Aug 8, 2005 03:04 PM
TuRtLE714
19
Apr 27, 2005 01:24 PM
Boilermaker1
Feb 20, 2004 10:58 PM
MangoEX
Nov 26, 2003 08:24 PM
luukass
May 28, 2002 01:59 AM
