Forget Camber-Kits! (Article I found)
Old Nov 26, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Monroe Launches Magic Camber
Magic Camber - an all-new product from Monroe - has been designed to correct camber problems that, to date, Monroe claims have been difficult and expensive to solve. Peter Goodrich, Product Manager for Monroe Australia, said a number of factors could adversely affect a vehicle's wheel camber.
"Driving with tired springs, lowered or raised suspension, over kerbs or fitting lower or wider profile tyres can change the camber of the wheel," said Peter.
"Not only is tyre wear increased, it is also uneven, and tyres have to be replaced more frequently. Driving on uneven tyres can also be extremely dangerous as they can make the car pull to one side and dramatically increase braking distances. Magic Camber comprises a set of two special bolts that are fast, easy and safe to install and can be used on any vehicle with McPherson struts that are mounted to the stub axles by clevis bolts."
It takes just a few minutes to complete a professional readjustment of the wheel camber with Magic Camber. The mechanic simply replaces the upper bolt currently holding the lower end of the McPherson Strut in place with the Magic Camber bolt. This allows the camber to be adjusted by three degrees either side of centre while the vehicle is on the wheel alignment tester. Magic Camber has been tested and approved by Germany's technical standards agency TÜV.
Old Nov 26, 2003
armieo's Avatar
< My future wife.
looks magically AS SEEN ON TV. and half of those things don't even work lol. Take oxi clean for example...
Old Nov 26, 2003
civicvtec1ps's Avatar
Search and Learn
Ehh just like any front camber replacement bolts...
Old Nov 26, 2003
CivicHX01's Avatar
it looks almost identical to my SPC front camber kit
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
viperGTS
Jul 27, 2015 08:40 PM
1khilari
Jul 9, 2015 08:12 PM
