Just got camber kit on and alignment..still pulls? UPDATE
Old Apr 24, 2005
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
Okay im completely clueless, but here is wat happened. Im rolling on nuespeed sport springs w' SPC frnt and rear camber kit. I went to get it my wheel aligned and camber adjusted. Im asumming that getting camber kit i will be all good. But the guy said that "my front is in red zone for camber and there is very lil play"...here is the specs i got. BTW i got 02 civic ex
Front left:
-1.5 - camber
1.6 - caster
.02 - toe
Front right:
-1.4 - camber
1.8 - caster
.02 - toe
Rear left:
-0.7 - camber
.09 - toe
Rear right:
-.6 - camber
.06 - toe
I dont know what the numbers mean but i thought once u get camber kit, everything should be corrected. Also my steering colum is not centered and it still pulls to the right a lil bit. Should i go back and have them fix? Can they fix the steering colum so it is centered?
Old Apr 24, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
The shop f*cked up your alignment... they didn't have the wheel set to center when they did it. Take it back and tell them to redo it because the car pulls when the wheel is centered.
Old Apr 24, 2005
TuRtLE714's Avatar
wat about the camber specs? is that correct when you get spc kit on?
Old Apr 24, 2005
robbclark1's Avatar
Retired suspension supermod.
the front is a little more camber than usual, but it works. I suggest reading up on camber, caster and toe before you get your car aligned next time so you can tell them what to do and whether the fvck up or not. There is information in the autox forum.
Old Apr 24, 2005
scatman's Avatar
Still in the game...
yea if you got the camber kits and an alignment, the shop definately screwed you. i have had more than 5 alignments done while dropped and all were successful.
Old Apr 25, 2005
Gangsta Dave's Avatar
People Eating Tasty Animals PETA
Gangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to all
ok I had that problem and had the alignment.. it didn't help and they said it had to be the tires.. I was like whatever because the tires are only a year old if that. Well I put on my new rims and new tires and I'll be damned.. it is driving straight and I didn't even go to get another alignment. It sounds crazy but it could be the tires, I would have never believed those guys. I thought they didn't care and were trying to rush me out of the place.
Old Apr 25, 2005
TuRtLE714's Avatar
tires are only 300 miles on them
Old Apr 25, 2005
BiGDoG's Avatar
BiGDoG is on a distinguished road
Maybe u need air in ur right tire?
Old Apr 25, 2005
TuRtLE714's Avatar
UPDATE: i went to alignment place again and they said i installed front camber kit wrong. Thing is when i installed it...i tried putting it on the upper bolt first..thing is that it didnt go all the way in. So i tried the bottom one and it fits. How is everyone elses?
Old Apr 26, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
If the steering wheel is off center, they did a crap job. What is probably happening is when you straighten the wheel, the car wants to pull, cause in reality, you are moving the wheel. You could have installed the camber bolt upside down and backwards, but that has nothing to do with the wheel being crooked. Make them fix it. Damn I wish you guys were all around me, I get tired of seeing how much s****y alignments some of you have gotten. My alignment guys are both sharp, and I don't allow this kind of crap in my shop.
Old Apr 26, 2005
TuRtLE714's Avatar
but the camber bolt is suppose to be at the top one right?
Old Apr 27, 2005
TuRtLE714's Avatar
anybody?
Old Apr 27, 2005
wonderz's Avatar
wonderz is on a distinguished road
yea, it goes on top.
as for fitment, both (top and bottom) stock bolt size should be the same. maybe your shocks is not really lined up when you tried to put it on the first time.
Old Apr 27, 2005
TuRtLE714's Avatar
its it suppse to be kinda snugged when bolted down?
Old Apr 27, 2005
wonderz's Avatar
what u mean by snug? i mean it just goes in and doesn't move around.
Old Apr 27, 2005
TuRtLE714's Avatar
http://www.spcperformance.com/PerfTe...rojHon1_F.html
referring to the last two steps.....the not the washer but after that the .5 inch black thingy...doesnt go thru ....it stops there and i move it around it doesnt go snug in as the last step. did thye send me the wrong size?
Old Apr 27, 2005
wonderz's Avatar
half an inch doesn't fit is lot...
did u check to see if u got the correct size? like part number and stuff...
so did the black thing go in?
Old Apr 27, 2005
mackin's Avatar
mackin is an unknown quantity at this point
hey i got my alignment done the other day .everything is good exacpt for the front right camber...it's -1.5 compared to the left front which is -0.9
the guys at the tire shop said the max front camber they could get is -1.5 and the more he turns the top bolt it just goes back further off camber......
anyone wiht any suggestions of wat i can do??
also...the steering wheel shakes when i'm on the highway....is that just cus the wheel is not balanced good or?
anyways i'm goin in for another alignment today
any suggestions would be great
thxn
Old Apr 27, 2005
mackin's Avatar
oh btw, i'm on neuspeed sports on stock shocks with spc front and rear camber kit , running 17s wiht 205/45/17 tires
Old Apr 27, 2005
TuRtLE714's Avatar
yeh i got the right part number...gonna try it tonight.
Makeice3498
Jul 2, 2015 11:13 AM
ayzan
17
Jun 30, 2002 12:36 PM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
ImmortalEX
Oct 31, 2001 10:00 PM
