Front hub and bearing [solved]
2003 civic Ex. Ihave the Timkin bearings and we started the job. Buncha questions for those who used them.
1. which side faces the clip? Rubber or steel?
2. how much clearance is needed between the inside of the hub and the knuckle? That is to ask, how far do I press in the hub?
3. do 1 and 2 matter much?
re: Front hub and bearing [solved]
Checked YouTube for a video?
1aAuto usually has good ones, Chrisfix did one on a DelSol that would probably be the same
And the hub gets pushed in all the way until it bottoms out.
Yup I figured this out. The rubber faces the clip on the outside. This bearing has no mag ring. Timken tells me it doesn’t matter which way you put it in there.
guitarsnlikker
Oct 25, 2016 04:25 PM
SpecialKPB
Aug 22, 2011 11:34 PM
hardboil
Feb 10, 2009 04:11 PM
