front wheel hub bearing
Old Jul 29, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
i got a noise coming from front left wheel. i believe its the wheel hub bearing. sounds like metal to metal type of contact swooshing. can anyone confirm this.
i had a shop replace a stripped stud, before the install, no noises, after the replacement it made the noise cuz he "banged off the hub" should they not buy me a new bearing and install it?
Old Jul 31, 2005
Bigfella's Avatar
Bigfella is an unknown quantity at this point
Does this help??http://www.7thgencivic.com/forums/sh...d.php?t=219261
Old Jul 31, 2005
xDCx's Avatar
yea i read that thread and a few others. i shoulda jus replaced the bearing when i had the stud replaced. which is somethin the shop didnt even recommend until AFTER it was done so they can double charge on labor. i bought a new bearing already jus waitin on a few people to let me kno if they can fix it this week.
Old Jul 31, 2005
streetglower's Avatar
well there is your problem, the shop "banged off the hub". The wheel bearing is attached to the hub assembly so they probably damaged the bearing. with the studs, you are supposed to remove the knuckle, press out the hub assembly then press out the wheel bearing. You should make the shop buy you a new hub assembly.
Old Jul 31, 2005
xDCx's Avatar
they are claiming it was in poor condition already from driving around with only 3 lugs for a while. which is major bs cuz i dont think that can cause any serious damage in a short period of time. i went back to them and bitched them out and got $30.00 back for labor of replacing the stud.
Me - "your shop sucks u ****in low budget garbage mechanics"
Old Jul 31, 2005
xDCx's Avatar
im gon back on monday to speak with the owner
Old Jul 31, 2005
driving around with 3 lugs will not hurt anything. 3 lugs hold the wheel on as tight as 4 lugs do.
Old Jul 31, 2005
xDCx's Avatar
im goin to shop tomorrow if not tomorrow no later than tuesday so i'll update.
Old Aug 1, 2005
xDCx's Avatar
spoke wit the owner and they are going to install new bearing free of charge. so i got $30 back and free install when they were trying to give me NOTHING out of it at first. Just a heads up !
Thanks Bigfella and streetglower for the help.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
edspyhill09
Jun 12, 2016 02:45 PM
Supramk3
Jun 11, 2015 11:13 AM
bsmiley
Apr 27, 2015 01:27 PM
crazydragon
Nov 7, 2001 05:13 PM
