Extremely rough on concrete Highway, smooth as glass on asphalt
Old Apr 6, 2023
CivicChoice's Avatar
CivicChoice is an unknown quantity at this point
Like the title says, my 02 Civic 136,000 indicated miles has relatively new struts and springs and tires. Recently this phenomena seems to be getting worse. When I drive on the freeway which in Southern California is mostly concrete, the car feels like it's going to shake itself to pieces and the wheels are going to fall off. On asphalt roads, smooth as glass. No problem at all regardless of speed. I have read this is a problem on some Toyota pickup trucks but I don't think we share any suspension components.
Any suggestions on what I might be able to do to smooth it out or absorb the shakes better? The steering wheel literally vibrates back and forth about an inch in each Direction. Car tracks straight.
Old Apr 6, 2023
Re: Extremely rough on concrete Highway, smooth as glass on asphalt
what did you use? Monroe quick struts? They are crap
Old Apr 6, 2023
Colin42's Avatar
Crappy tires
Old Apr 7, 2023
Tires are Falken, Struts are blue in color, no idea the make I didn't install. Could there be other bushings that amplify this effect when worn?
Old Apr 7, 2023
better check all bushings, any of them could cause it
civicstylz4u
Jan 26, 2004 03:20 PM
mcochran
Sep 12, 2003 06:55 AM
cobrapimp
Apr 17, 2003 01:03 PM
AnotherDopeStyle
Dec 21, 2002 10:00 PM
drang01
Dec 17, 2002 12:08 AM
