tracking down source of steering wheel wobble
Old Jun 11, 2021
johnnycr's Avatar
johnnycr is an unknown quantity at this point
I could use some suggestions to help track down the source of a steering wheel wobble. My steering wheel wobbles between 55-65 MPH. It's not severe, but obnoxious. I just finished replacing most of the front end, including rear control arms, sway bar links, struts, ball joints, and inner and outer tie rod ends. I did not replace the axles or wheel bearings. I also replaced the rear struts. After doing all the suspension work, I had the tires balanced and an alignment done.
The front brakes are new. The pads and rotors have about 5,000 miles on them. The driver's side wheel bearing and axle were replaced in 2018, and I've probably driven about 15,000 miles since then.
At this point, I'm not sure what the source of the wobble could be. The bearings seem to be okay. When I had the knuckles off, they both felt smooth when I spun them by hand, and there doesn't seem to be any play when I shake the tires now that everything is installed. I'm suspicious about the driver's side axle shaft that I replaced 3 years ago. I got a cheap Cardone axle from Amazon, and it's already way more rusty than the Honda axle on the passenger side that is much older.
Any suggestions? What can I do to track down the problem? Thanks!
Old Jun 11, 2021
Colin42's Avatar
Re: tracking down source of steering wheel wobble
I would guess tires, try swapping them front to back
Old Jun 11, 2021
johnnycr's Avatar
I did try that as well, and there was no difference.
Old Jun 11, 2021
steering system itself
subframe and bushings
cracks in the chassis (I have seen some)
You mentioned rear arms, what about the fronts? (I also had cracked arms, hard to see)
Old Jun 11, 2021
johnnycr's Avatar
Oops, that was a typo on my part. I meant "lower" control arms, not "rear" control arms. I did replace the front lower control arms. Other than the two bushings on the front lower control arms, are there other bushings that I should check? And when you say steering system itself, what could cause the wobble at high speeds? The rack? Pump?
Deeznutsmaketea
Jan 2, 2015 01:11 PM
tweav88
Nov 11, 2012 08:24 AM
LividHatred
Jun 20, 2012 03:15 PM
aaronhahn777
Apr 21, 2011 10:28 AM
1955
Feb 13, 2005 05:36 PM
