My new CV shaft isn't fitting into my knuckle
I bought two new CV shafts for my 01 Civic. I've only just removed the right side and attempted to install the replacement, which looks identical to the removed piece. When I try to get the outer splined part of the shaft, it fits into the knuckle but not far enough for the nut to grab on.
Is there something I'm missing, or is careful progress what I should be looking at?
I've greased the splines. I've whapped the knuckle with a rubber mallet. I've pulled and reindexed the splines to the knuckle...and I didn't notice any flat index mark that should be lined up to ease the install.
What I've been doing, before it got too dark outside to see anything, was I threaded the axle nut on backwards and pried on it a little to draw the shaft into the knuckle. It's been working pretty well/slowly, but I'm not sure that brute force and ignorance will get me through this ordeal.
Be that as it may, I think that the splined shaft should probably just slide right into the knuckle and it's not. Should I just continue my prying routine that is maybe working oh so slowly?
Is there some index mark I'm missing that's getting galled up as I force these parts together?
Maybe it's a matter of RockAuto cheapie parts just not machined quite as nice as factory parts?
I've got a few days before this has to be back together, so maybe someone can help me out between then and now.
Merry Christmas!
Merry Christmas!
Re: My new CV shaft isn't fitting into my knuckle
then slightly turn the shaft while you tightens the shaft nut. meaning try to turn it until the splines align. be careful and hold the axle far from anything. for when the splines align, it could snap in suddenly it could also be out of alignment, so you could push it into different angles (CV joints are designed to change angles, so this could help it.)
mine went in with a bang
RIPSAW
Jul 14, 2016 08:21 PM
coolfez
Apr 26, 2011 07:07 AM
Spartanic
Jun 30, 2009 07:50 PM
