Electric power steering, Violent shaking
Old Nov 7, 2022
Lzzgundam's Avatar
Lzzgundam is an unknown quantity at this point
Unhappy Electric power steering, Violent shaking
Hello,
I have scoured the forums for the information needed to complete the EPS swap on my 04 em2. After gathering the components and installing all the items I'm down to the wiring. Currently my BCU for the EPS rack is wired into:
BLU/white - VSS to A18 white/green
Yellow - ING to E9 yellow/black
RPM - Blue to E26 - Blue
I can hear the BCU click on with the car and I have confirmed voltages, but the issue is that the steering wheel violent vibrates, and with any amount of added pressure on the wheel it rotates full lock to the left then full lock to the right repeatedly. And if I were to let go of the wheel it begins to violent shake again. This is all while sitting idle in my driveway.
Please help!
Old Nov 14, 2022
BrotatoChip's Avatar
Super Moderator
Re: Electric power steering, Violent shaking
One of the wires to the module is for a malfunction indicator in the cluster, it will give you blink codes for any issues. Might be a good idea to hook it up and see what it thinks is wrong.
Old Feb 8, 2025
es1_k24A2-PRB's Avatar
es1_k24A2-PRB is an unknown quantity at this point
Having the same issue with a newly installed EPS. Same three wires are connected plus power and ground. There was mention of connecting a wire to see what the light blinks were to identify the issue. Which wire and connect to what?
slvgga
General
Feb 5, 2020 03:59 PM
Terrys2012honda
Dec 3, 2016 12:51 PM
Black04ex
Nov 25, 2005 01:44 AM
zackde
Nov 8, 2004 01:24 PM
