Inner Tie Rod Replacement Question
I just recently replaced my steering rack, and should have replaced my inner tie rod and outer tie rod ends when i had it all out, but i didn't. The steering rack is good, but my inner and outer tie rods are shot. Is it possible to replace the inner tie rods without dropping the steering rack again? Any recommendations are appreciated, thanks!
Re: Inner Tie Rod Replacement Question
Yes, absolutely.
Required turning the rack one way or the other to gain (at least a little) access to the inner tie rod ends. Not easy but definitely easier than removing the rack.
