View Full Version : Honda Civic Fuel, Oil, Cleaners & Other Maintenance
Pages : [1] 2 3
  1. Fuel Economy
  2. 10,000 mile oil change
  3. oil/fuel Additives
  4. Which fuel additive to use at 30k?
  5. Fuel System Cleaners and Additives?
  6. don't use premium gas
  7. New top tier gas
  8. Good to be here!
  9. Fuel quality declining
  10. Is gas any different?
  11. Fuel additive FAQ's
  12. Oil add FAQ's
  13. Highly recommed Used Oil Analysis
  14. Gas prices around the world
  15. FAQ about oil, fuel addatives, filters, and more
  16. FP effectiveness at 5k intervals?
  17. Can't find mobil1 5w-20 anywhere!!
  18. 5000k for oil changes?
  19. Do you use Fuel / Oil additives ?
  20. water in gasoline?
  21. How Do You Change Manual Transmission Fluid
  22. Oil Change Question
  23. Automatic Transmission Fluid. What kind?
  24. coil-over plugs
  25. Fuel Rail, 99-01 the same? HELP!!!
  26. Car makes sounds .. any help
  27. tranny
  28. Super gas mileage!
  29. loud pop from my car
  30. fluids in our cars.....
  31. Maintenance light
  32. Fuel Gauge problems
  33. Fuel Power and Lube Control group purchase interest?
  34. scheduled service maitenence
  35. how often to change fuel filters???
  36. antifreeze?
  37. road trip
  38. Adding oil before 1st oil change
  39. hi flow cat + gasoline
  40. NGK Spark Plugs
  41. Automatic Transmission oil cooler ?
  42. Molybdenum helps with the break-in process, but when you change your oil...
  43. help with timing belt
  44. didn't change the oil filter
  45. Fuel Sending Unit/sender...
  46. seafoam
  47. oil leak?
  48. New Car Oil Change
  49. Sounds when starting car
  50. Oil Changes & 10,000 mile maintenance
  51. 5k,10k,15k oils
  52. lubecontrol gets the thumbs up. :)
  53. injector cleaning service??
  54. 40,000 MI service?
  55. 60k - what should be done?
  56. Maintenance required light
  57. Detergents and Magnesium?
  58. hamp filter
  59. A/C fuel DIY?
  60. atf
  61. "Higher Milage" 5w30 or 5w20?
  62. Engine Shampoo Question
  63. Oil pan gasket, 95
  64. K&N Air Filter
  65. Anyone with SLPs Return Fuel Kit, I need pics
  66. Air Filter
  67. exxon/mobil vs chevron
  68. "Pour in the performance?"
  69. type of oil
  70. Anyone using an S2000 oil filter?
  71. Nasty Odor From A/C?
  72. very low mileage in city AND highway...why?
  73. Question about octane booster
  74. taking a 3000+ mile trip, what to do?...
  75. coolant change instructions and reminder
  76. Maintenance light for oil change?
  77. What kind of aftermarket fluid for A/T ?
  78. great engine oil, and great for your wallet!
  79. need some advice
  80. Acetone test
  81. Walbro fuel pump
  82. 60k questions, save me from honda dealers
  83. Gas Mileage
  84. How to siphon gas out of our cars?
  85. Oil Changes... First and Thereafter
  86. 5w-30 vs 5w-20 vs 0w-20 vs 0w-30
  87. will it hurt?
  88. Going from 10W-30 back to 5W-20?
  89. Are they the same?
  90. BG Fuel Products?
  91. Wheres The Diy For Mt Fluid Change
  92. lube control's fp60
  93. Link to dino UOA with LC20
  94. Oil Recommendations
  95. Free Garmin eTrex or Magellan GPS!
  96. Amount of oil
  97. Redline Vs Royal Purple
  98. Group Buy is up
  99. wat type of coolant do i use?
  100. Power Steering Flush Procedure?
  101. Real Racing Oil: Motul
  102. is there a clean way to change an oil filter
  103. AC Help
  104. remove bumper to change oil.
  105. Whats stock injector size? also would 440cc injector be good for turbo?
  106. Castrol GTX or Exxon Superflow
  107. just got 440cc injectors where do I get clips?
  108. fumoto oil drain valve review
  109. Mobil 1 extended performance
  110. Is adding additives to your Eng. good?
  111. Cleaning particular parts of the engine?
  112. First Oil Change for Me and the Car, Require Assistance
  113. Starter
  114. Anybody ever use the Honda Performance Tranny Fluid?
  115. Doing my own oil change for the first time~~
  116. Fuel Pressure Regulator Installation
  117. fp60 is amazing
  118. B16A swap, fuel filter leaking???
  119. where to get the honda stuff
  120. When is it time to change Radiator?
  121. 21 points inspection
  122. Wheres The Oil Filter?
  123. 10,000 miles W\O oil change
  124. ok to go thinner weight?
  125. fuel 98 civic?
  126. how to change spark plug
  127. how often to change the injen cold air filter
  128. torco sr1 oil
  129. Amsoil syncromesh
  130. I Need All The Power I Can Get
  131. right spark plugs?
  132. K&N filter for AEM V2 intake?
  133. What new sparkplugs to get?
  134. seamfoam brake booster hose where ???
  135. K&N oil fliter OR Moblie 1 oil fliter
  136. Best Place to Jack up front of car...
  137. Stock Air Filter Box ??
  138. post your mileage
  139. FP60 Discount
  140. OIL: from an engineer's view
  141. car fluids?
  142. (Newbie) Hanging Exhaust?
  143. engine oil question
  144. Best Tranny fluid (automatic)?
  145. redline used with normal oil filter?
  146. coolant change
  147. Time for a tune up need some info...
  148. Oil leak
  149. Independent Motor Oil Testing??
  150. What kind of Oil to use
  151. oil question???
  152. Aftermath of additives with oil change...
  153. 89 Gasoline
  154. fuel tank max fill
  155. first time synthetic ?
  156. Honda Type 2 50/50 Coolant - where to get?
  157. removing bolt-ons = better mpg?
  158. K&N filter cleaner on OEM airbox filter
  159. Approaching 70k Miles: What Maintenance to Be Done?
  160. Just received my LubeControl products!
  161. Fuel consumption.
  162. Lubecontrol.com Group buy expiring soon!
  163. Cabin Filters
  164. oil filter
  165. need a straight answer
  166. the marketing of synoils (synthetic oil)
  167. Free Garmin eTrex or Magellan GPS!
  168. 20k Maintenance
  169. gas quality
  170. Wed August 31st last day for Lubecontrol.com Group Buy
  171. Synthetic Oil Question.
  172. Urban myth?
  173. vtec-e
  174. motor sitting for months?
  175. Jack Stand or Ramps?
  176. Fp60 ??????
  177. Best oil to use for 02' Honda Civic
  178. o2 sensor replacement interval
  179. Mechanics and techs alike....
  180. Why do I have blue coolant?
  181. Gas mileage.
  182. Stupid Brother, NEED HELP !
  183. Timing belt and fliuds change???
  184. ok so has anyone ever...
  185. what would you do to improve gas mileage and power?
  186. lc20 oil treatment review
  187. Radiator flush vs. cleaner
  188. EGR valve, where is it, and how can I block it off.
  189. Changinh plugs
  190. my experience with changing tranny/motor oil
  191. Is anyone running the DSM "Blue tops" 450cc?
  192. AEM's New DryFlow Air filter
  193. Are all synthetic oils the same?
  194. Seafoam
  195. Would these SparkPLugs Work. "Hurry"
  196. Do you bring your own oil and filter?
  197. Prestone Brake Fluid
  198. maint. req'd.
  199. WD-40 on wheel studs and lug nuts?
  200. Did mobil get bought by lukoil?
  201. Tranny fluid..
  202. oil change problem
  203. fuel injector cleaner / techron
  204. 41 mpg~!!!!!!!!!!!!!!!!!!!!!!
  205. 30k mile maintanence?
  206. changing tranny filter
  207. Engine Coolant
  208. Cleaning KnN Filter on Intake
  209. Fuel Mileage for 2002-05 Civic Si/SiR
  210. 60,000 Tranny Fluid Change?
  211. Door weather strip lubercant
  212. Castrol Oil
  213. Amsoil XL5w-20
  214. Here is Excel MPG Template
  215. More than you need to know about engine oil.
  216. Any recommended maitenance at 80,000 miles that I may of forgot about?
  217. B&M trick shift ATF
  218. 30-50 mph- Acceleration problem
  219. 13.2 sux I want more
  220. LubeControl LC20 and FP60
  221. new oil pan
  222. honda dealer and maintenance
  223. Front rim's really greasy
  224. Is Time For My Tune-up
  225. royal purple adds hp !!!
  226. i need a new power steering reservoir and..
  227. What Antifreeze
  228. Gas Line Antifreeze?
  229. oil drain bolt washer ?
  230. 1.7 liter 04 em2
  231. Gas stations cheat you?
  232. too much oil
  233. Octane Question
  234. Still at a loss on this sparkplug thing
  235. anybody use antiseize ??
  236. Clutch Fluid Flush
  237. 89 octane = reduced mpg
  238. Redline or Genuine Honda ATF
  239. LC20 and FP60 Christmas / New Year sale!
  240. Overfilled gas tank
  241. valvoline oil
  242. How low have you gone (on the gas gauge)?
  243. Do auto tranny treatments work?
  244. 1st oil change for low mileage car
  245. Where did 1 litre of oil go?
  246. best brand of motor oil?
  247. Have any of u heard of Maxi-Lube?
  248. B&M Trickshift ATF Synthetic
  249. Royal Purple Synchromax Manual Transmission Fluid
  250. can you use reg unleaded in new 06 civic si?
