Summer gas, cooler temp?
Old Apr 23, 2013
clinton_hedrick's Avatar
clinton_hedrick is an unknown quantity at this point
I have noticed that the temp gauge on my car seems to be running a little lower for the past week or two than it has been. I think the gas stations have switched back to the summer gas blend, because last tank I saw an increase of about 3 mpg. Would the summer gas blend cause a cooler operating temperature? Just curious, it isn't much of a change
Old Apr 23, 2013
Re: Summer gas, cooler temp?
I'm not certain when fuel blends change for the season (Google it!), but I think that consistent warm weather alone can explain this.
My mileage has been slowly going back up too.
Absolutely not. Completely unrelated.
Oh hell, here. I googled it.
Read this: http://www.epa.gov/otaq/regs/fuels/rfg/f01033.pdf
Looks like the storage terminal has to have RFG fuel by April 15, but your local station may get it a bit later than that.
http://www.api.org/policy-and-issues...e_requirements
http://www.api.org/~/media/Files/Pol...ments_Map2.pdf
Old Apr 25, 2013
Ok, JW. I could be imagining the lower temp reading. And I think it did switch gas, I went from 35 to 38 mpg from one tank to the next, with little change in weather. It's a welcome sight
Old Apr 25, 2013
sl33pyriceboi's Avatar
hotter air coming in your intake (to a certain point) will yield better mpg.
Old Apr 26, 2013
Yeah it helps, but Ohio weather forgot about spring this year. Frost again this morning.
Old Apr 26, 2013
CraigW's Avatar
Even with temps in the 30s I can keep my temp gauge down by blasting the heat in the mornings. Turn down the fan speed and gauge soon pops up to normal mark.
mjdiaz89
Jun 21, 2016 09:26 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
Jul 14, 2015 03:39 PM
silentz
Jul 9, 2015 08:16 PM
cgavin1
Jul 7, 2015 07:10 AM
