Civic stalls out and won't turn back on
Rep Power: 0 Civic stalls out and won't turn back on
So I have a 87 civic I have had issue to we're i be driving and suddenly the car stalls out and when I try to turn it back on it won't turn back on,I can crank it but then once I release the key it turns off automatically I try to give it gas but it won't pump the gas I just had the fuel filter replace and disturb distributor cap and rotor replace but it still didn't fix the problem I think it's the fuel pump I don't think it's getting the gas it needs I sprayed starter fluid in the carburetor and it didn't do anything but the mechanic that did it the repairs said he sprayed starter fluid in the vehicle and it was able to turn over and stay on but 12 hours later after receiving the car back it's stalled out and it wouldn't turn back over but I'm able to turn it over and hear it try the idle but it won't idle what is my solution I'm thinking about buying a new fuel pump and replacing it because the car does get hot it does surge while I'm idling on a car at a stop sign please help me with a solution so I don't lose my only transportation
Re: Civic stalls out and won't turn back on
Dr Krieger of Modification
...did you test the original coil?
-Test all ignition related components before replacing them.
If you don't know how just google "ignition coil test civic diy".
Rep Power: 0 Re: Civic stalls out and won't turn back on
if somebody replaced if AAA replace my distributor cap and router and didn't put it in correctly well that cause the vehicle to stall out and not turn over because of the distributor not being timed correctly
So after the car stalls out while you're driving along, how do you get it started again?
[QUOTE=ezone;4748202]So after the car stalls out while you're driving along, how do you get it started again?[/OTE]
I don't start it doesn't turn over my mechanic just called me today and told me it's my ignition switch 280 bucks for the whole thing to be done with labor 200 without part if I order it or just 80 bucks if I buy it and put it in myself how easy of an install is an ignition switch
You'll have to do your own research and decide that for yourself.
BTW I don't know what parts you found, but it needs just the electrical portion, not the column lock and key cylinder.
Now I'm selling 87 Honda civic for 1500 on
replaced
radiator and thermostat
cv axles
spark plug and harness
distributor whole unit rotor and cap
fuel pump and fuel filter
put a new dual radio with for 300 watt Boss speakers
and a new ignition switch
replaced
cv axles
Brenda Morales
12-09-2017 03:38 PM
beeson76
08-24-2017 05:34 PM
laack
02-08-2011 08:14 AM
mc670
02-05-2011 08:20 AM
